I used to want one of those 40th anni front bars, then i saw one on a car and didn't like i, now I'm starting to like it again. Maybe I should cop one and just keep my standard S2 bar for if I feel like a change :P
Thankyou
nah, LM's come with the standard rims. these were put on by the original owner. Its a bit lower now as well
what do you mean by 3's
Sorry was in a rush, LMGT3 rims. I've never seen them in all gold like that, they look good.
I have white LMGT2's which aren't as common as the grey ones.
they are Nismo Rays LMGT1's, 18*10 powder coated bronze. originally white
^^^^^ is that a genuine GTR front bar? Hence making in "pull in" at the sides on stock guards?
Hey Grant. No not a genuine GTR bar - fibreglass copy but I think looking at the width.it was made to the same dimensions as the GTR bar. Once the bar is completely destroyed, I'm looking at getting the Series 2 stock bar and a viva garage lip. I posted in your build thread on JDMST about it - loving your 33 by the way. :)
GOOD STUFF ADAM :thumbsup: looks amazing..i have the same skirts n similar front lip edge (from this angle at least)
specs on the wheels?? rim size? offset? tyres?
thanks mate
Cheers mate! I've got top secret sideskirts and a mangled trust front bar at the moment.
Specs on the wheels are:
Koya Drift teks
17x8 +34 with a 30mm spacer and 20mm extended LCA on a 215/45/17 -4.5 camber
17x9 +30 something on a 245/45/17 -1.5 camber
Hi Buddy, saw you at the lights trying to get in to the entrance of the carpark that the eomm was being held at. Very nice 33!
Cheers bud! I saw yours roll in, looks good!
mmm, your username looks familiar, ever own an MX5?
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
