Looking for a Trust rear spoiler
Looking for a rear window spoiler as well.
If anyone has a lead or could possible ship this stuff to the USA please contact me. Its impossible to find any parts here.
Welcome to SAU Derek.
Look at F/S thread here on SAU + Post up a thread in WtB section too for your parts > good luck
And how on earth can you get away with a non-approved Skyline GT-R in USA? In some states you can have them? Other states they're crushed?
Excellent!
Is that your car mate?
If so, what size tyre are you running? im guessing they would be 18 x 10.5 +15? I have a set of 275 40s at home already.
Unfortunately it is not mine. He is a member of JDMST and it is a very nice example. Correct, sizing is 18*10.5 +15 all round.
GT-R looks terrific Grant!
If only it were mine Terry :(
I'm still stuck with the POS GTS-t on the previous pages lol.
i dont know for sure, but i was under that when the cars get to a certain age, they're a-ok in some states.
Excellent!
http://www.skylinesaustralia.com/forums/topic/393546-my-97-series-iii-bcnr33/
That's his build thread on here and I think it may have more details in his blog that's in his sig.. :thumbsup:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
