How do you guys get your front end to go so low on the std m spec body kits. i have 18's and if i go any lower than pictured below it hits the front hub assembly..?
i would like to go lower but even the slightest bump jerks my steering wheel off to one side.
Pictures from the recent "All Star Picnic Day" of the three r33s in my car crew:
White r33 gtr with diffuser with work meisters is Dominic's car aka Wangan
Pink Pearl R33 with work meisters is Eddie's car aka RBScreamer here on SAU
White R33 with AME Circlar Type Rs is mine.
And one solo of mine:
Edited by spacepants_fb
all 3 look awesome an your wheels are nice spacepants!!
Thanks mate. It's cool seeing 3 skylines which have been modified using slightly different approaches together in the one place. What makes it better is that because we're in the same crew, we can bounce ideas off one another (should we need advice on a particular mod, etc).
All look so hot and +1 on your wheels!
Thanks as well. Funny thing is I was thinking of getting rid of these wheels to get something with a step dish.
Nice. That's the viva garage / big win front lip yeah?
Yup, that's right Ric, Lip needed a bit of trimming for it to get on the bar though. If I was able to get the genuine front lip, I would have bought that instead.
Sell it to me then ;) it looks rad. Although I kinda want to do it in matte black
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
