This is the one http://www.ebay.com.au/itm/Nissan-R33-Skyline-Rear-Roof-Spoiler-Drift-Wing-Bobtail-Body-Kit-ECR33-RB25-/350974080474?pt=AU_Car_Parts_Accessories&hash=item51b7af75da
The fitment is ok. I painted it all up and stuff then sikaflexed it to the windscreen, Also taping it as tight as i could to ensure everywhere sikaflex was put was sealed and flush. I left it for about 5 hours with the tape on. It hasnt came off since. Being fibreglass it isnt the perfect measurements, but easy to work it.
May I ask how much for the front lip and where did you get it from?
Looks great!
Its just one of these universal rubber lips haha - http://www.ebay.com.au/itm/Universal-Lip-Kit-Suit-VW-Golf-Mk4-to-Mk7-ez-splitter-Mk5-Mk6-Volkswagen-/291055481269?pt=AU_Car_Parts_Accessories&hash=item43c44231b5
I think it does the job well for $40 :)
My old R33 GTST with RB26DETT
Current Series III GTR (Non VSPEC)
Annnnnnnd Roughly how it is now….
Specs of GTR before being pulled apart and semi stripped were;
Standard RB26
Steampipe Manifold
Precision 6262
60mm External Wastegate with 2 inch stainless screamer
ViPec plug in ECU
Siemens 750cc Injectors
External Surge Tank and single 044 with standard pump as lift pump
JJR 100mm thick GTR intercooler
JJR washer bottle/catch can
Bride Zieg III fixed back Driver & Passenger Seat
Defi BF gauges
Nismo Cluster and Triple gauges
JJR Oil filter re locater and 19 row cooler
Exedy Compe D Twin plate clutch
RS*r 3 1/4 inch catback exhaust with high flow cat
At one stage had a PSI parts Carbon rear diffuser
Carbon lip spoiler (GTR wing was removed)
All Alpine type r sound gear and focal sub
HKS HypermaxIII coilovers
18x10.5 + 12 SSR SP1R wheels
<br />Any chance u remember the sellers store?<br />Fitment looks pretty sweet, any issues?
Check back a couple of pages, I got my roof spoiler off ebay too. It was a VivaGarage item and I assume it is the same mold as this one. Fitment wasnt the best and it had to be heated up and played with to get to fit right in the end.
What size and offset are your rims on the gtst mate?
Annnnnnnd Roughly how it is now.
Standard RB26
Steampipe Manifold
Precision 6262
ViPec plug in ECU
Defi BF gauges
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
