Hi guys, I had a problem with 4th gear at Sandown on the weekend... when shifting from 3rd to 4th, close to redline say above 6,000rpm, I was getting a nasty crunching sound... now it would still go into gear fine and it was only happening when I was trying to shift quickly (if I eased it in there was no sound, but it meant for a fairly slow change)
...so my question is, do I need to get the box out asap and fix it or can I get away with a few more trackdays/drags etc without losing 4th gear altogether? Am I stupid for not worrying about it? (Maybe I can smash the whole lot so I am forced to go out and by an OS giken gearset hehe)
https://www.sau.com.au/forums/topic/130510-syncro-on-4th-is-not-happy/
Hey,
When the gear is crunching you are doing damage to the sleeve that actually does the job of engaging the gear.
Yep, your 4th synchro is most probably worn.
Do this enough and even without breaking anything else you'll burr the front of the teeth on the sleeve - which
will probably make it difficult to get it into gear and then keep it there.
Getting replacement sleeves for some boxes is hard (e.g. I can't get one for my 32GTR box; I have to
upgrade the entire 1st-3rd train in order to be able to use a different 4th sleeve). Your box might be different.
Don't know your box; but on mine 1st, 4th and 5th synchros are 1-piece; 2nd and 3rd are 3-piece.
This is probably why 4th seems to go first on GTR boxes :)
The long and the short of it - I would fix the synchro before you do more damage. They are wearing parts
and should be relatively cheap to replace - the hardened sleeves and/or gears are _not_ cheap
to replace assuming they are even available. You probably want to do 3rd and 4th synchros.
Do a bearing set while you're in there and you'll probably get another 10-15 years of motoring out of the box :)
Regards,
Saliya
Redline themselves say that the shockproof is not to be used in synchro boxes.
I know that everyone on here thinks it's the bees knees. they put it in their box and it shifts like new. I totally agree there.
My issue lies with box longevity. Basically, a thinner oil allows you to shift smoother. e.g. if you put atf in the box. But also, it's a catch 22, it'll shift smoother for a dieing box, but it'll wear out much quicker too.
Lets just say that my box is notchy too. I just live with it. I'd prefer to kill it by notching it occassionally, rather than it dieing from redline shockproof.
Hey,
This is probably why 4th seems to go first on GTR boxes :mad:
Do a bearing set while you're in there and you'll probably get another 10-15 years of motoring out of the box :stupid:
Regards,
Saliya
I am pretty sure the 32GTR and 33GTSt boxes are very similar and I am now seriously considering a freshen up before I do damage to more than just the synchro, thanks for your help
Hey,
This is probably why 4th seems to go first on GTR boxes :D
Do a bearing set while you're in there and you'll probably get another 10-15 years of motoring out of the box ;)
Regards,
Saliya
The syncro may be cheap but getting it installed isnt thats for sure I had mine done 3 years ago costs a bloody fortune.
cheers
cheers
Put it this way: the labour cost is going to be roughly the same whether you do 4th gear synchro only, or an entire
rebuild on the internals of the box (getting to the 4th gear synchro probably requires complete disassembly).
So it might be 'a fortune' now; but when a sleeve is burred or smashed and it's not replaceable, it's 'a fortune' plus
another few large :)
(Yes, you can buy secondhand drop-in boxes of similar vintage - but aside from the 'you haven't seen it running
and/or disassembled, so how do you know it's any good' factor, any box that's of roughly the same mileage will
probably have roughly the same problems...
Regards,
Saliya
Got the exact same problem with my 'line last nite.
Shifted up from 3rd to 4th at about 5000rpm, nasty crunch.
Looks like the box will be comin out to replace teh synchro's. fun! :huh:
dont feel to bad mate.. i was shifting from second to third in my 34 gtt and ripped every single tooth off third. the box was like new up to this point and showed no signs of wear (even had perfect syncro on reverse which is almost unheard of)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
