Someone told me they know of one to suit skyline.... thats the one im looking for.
Not much help but they do make em.
http://www.difftechnics.com.au/gto_nine_irs.html
Were any XE or XF Falcons IRS?
why would you want to do that?
if you want a diff wich is much stronger just use a z32 tt diff.
r220. 220mm vs 9 inch 228mm.
it will bolt up using gts4 driveshafts and WONT BREAK. not sure about the axels but.
how much power are you running?
r200 diff's and r32 driveshafts/tailshafts have a reputation for handling as much power as you can throw at it.... 9 inch conversions are very uncommon because the stock diff is strong enough...
Stuart's car will make a shitload more power and torque than my car and I explode CV's and snap axles 2 at a time with 265kW.
R33 GTST R200 LSD's and std axles = Rubbish in my opinion. The only reason people say they're 'strong enough' is because 99.9999999% of Skyline drivers ESPECIALLY the ones with big HP cars NEVER race their cars hard. They're all soft - especially the GTR drivers :D
Adrian
Hmmm.... Z32 R220 with standard gts4 axels or braced 9" with billet axles.
Tough decisions...
Adrian
oh, im sorry. lets see. a diff that bolts up.? or a bulky 1950's based bigger is better truck diff? not that theres anything wrong with them. just try finding one that has a nodular iron case and doesnt use a floating inner axle design.
il choose the r220 and perhaps using shortened r33gtr 31spline axles. hks and pretty much any other 1000hp drag gtr seems to do ok
worst case just get some "billit axles made to suit the diff that fits? or you could try and cut n shut a 9 inch.
dave
but... if you were seriouse you could probably convert the car to a 4 link set up. that would work best. and the nine inch will be very well suited
It's got nothing to do with being serious or not. It comes down to what you can do in the class you want to race in.
Thanks for all the info guys, i am running the car in Oz so 4 link is out and dont have spare 10k to throw at it. I have the R32 GTR diff and shafts fitted, sound like they may be up to it, ill just put a mechanical centre in once i know what gear ratio i want. TRPs R32 skyline has given me some faith.
TRP's R32 ran mid 9's off transbrake with an s15 centre and gtr driveshafts, don't know how much faster you want to go.
Wise move Stewie...no point trying to re-invent the wheel
R33 GTST R200 LSD's and std axles = Rubbish in my opinion. The only reason people say they're 'strong enough' is because 99.9999999% of Skyline drivers ESPECIALLY the ones with big HP cars NEVER race their cars hard. They're all soft - especially the GTR drivers :)
Adrian
Adrian, what do you mean by race hard??
thanks :P
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
