Hi,
I have a R32 GTS-T. Mods include full exhaust system, boost controller, coil packs, air intake and soon to be fmic and apexi fc. Just a question? Is it possible to get this baby to smoke your average R33 or R34 and even stand in the shadow of a GTR?
I've been told they have no bottom end but there must be a way to fix this? Any points of view out there. I just think that If I spend another $10000 or so on carbon bonnet, coil overs, bearing turbo, fmic and other items without knowing what its worth.
https://www.sau.com.au/forums/topic/130637-rb20-better-than-rb25-or-26/
  • Replies 49
mod for mod, the 25/26 wil always beat the 20 due to its extra capacity. however there are a few highpowered RB20's arounjd the place that with a grippy set up car would more then likely blow away a stock GTR...
as for having no bottom end.. well they are only a 2 litre motor, so you either need to rev them to get power, or add capacity
either way, i love my rb20, makes great power for bugger all bucks!
dollar for dollar spent... RB20 wont ever match an RB25/RB26
Its just not going to happen. Capacity dictates much more broad power curves so more power, for longer.
The only way to be better, is to spend more, and i mean a LOT more money than the other person
Hi,
How do you mean "beat" a GTR? Can the GTR be modified aswel?
Power FC, GTR injectors and a HKS GT2530 will give you 270ish rwhp, and a well powered, reliable and responsive RB20DET. going any bigger turbo will give you excessive lag, unless u like lag :)
Edited by _8OO5TED_
rb25 has a far better head for flow than rb20 so you're already losing
the 500cc difference means squat all in comparison in my opinion
rb25 isn't built any tougher than an rb20 though, so you'll bend or break things anyway
Dont forget, R32 GTSt is between 1250-1300kg. An R32 GTR more like 1550kg. So you dont really miss the torque as the car is reasonably light.
If you want general all rounf performance keep an eye on power to weight. An R32 GTSt with 230rwkws will not be a slow car. With sensible suspension, wheels and tyres it will do mid 12s at the drags, and be on par if not quicker then std turbo GTRs. (Gross generalisation but i think there is some truth to it)
The head flow thing is interesting as well. Sure the RB25 has bigger valves, but what is the ratio of the cc of each cylinder to the total inlet and exhaust valve face area?
I have never done the calc, but could be interesting. Ditto the SR20 vs the RB20, as each cylinder has less cc, and the smaller physical valve size may not be such a big deal when you look at it as a percentage of cylinder displacement.
rb20 = lag
but its f**king reliable and very kind to its owner...
not sure one could say the same for an rb26.. it generally needs money adn TLC to keep going from what i have read
With RB26 and being reliable, they need one good rebuild IMO and that cant include shortcuts, then go and abuse it however you please!
If you had a standard RB26 and didnt do boost exhaust etc and treated it well it would last for ages, the thing is, who buys a GTR to baby it? They're all driven as hard as they can be at one point in their life at least, and after 200,000k's in some cases you cant really blame them for bearing failure etc :O
Standard turbo GTR R32 running 15psi and clutch etc should do a mid to low 12 :laugh:
When are you GTR guys going to come to terms with the fact that your cars plain suck! :O
...lol and when are ppl going to stop comparing them? A neat GTSt will be a good all round car. A std GTR is a good all round car. From what i have seen a GTR doesnt have to be very modded to be an even better car, as the factory gave the thing pretty good gear from the start.
...doesnt change the fact that GTR owners have to use velcro shoes because they struggle with shoe laces :laugh:
Lol
I give credit where credit is due
I drove an R32 GTST, the boost never came, even though it was lighter than a GTR which was good i would still take a more peaky turbo/motor combo over the RB20 standard setup
:laugh:
Anyway this thread isnt about GTR vs the world, in answer to the question, you can get heaps of power out of the RB20 for the R32 shell (good power to weight i mean) but as for it matching a GTR, doubtful IMO, there are some out there with huge power, but power is no good without traction
...i dont :)
Im going to so kick some GTR ass at Wakefield....and if i dont ive got a long list of excuses already prepared. :)
LOL!!!
Ill be there, look for the guy hungover with an SAU shirt on and a can in hand - come say Hi :)
if u want reliability then stick with the rb20
funny that the rb20 is older yet seems there is many more 25's and 26's blowing up... maybe due to the fact that every man and his dog has either an r33 or 89 gtr
Also, the more powerful motors are thrashed harder IMO so they have a much harder life
Rebuild time is just a good chance to upgrade anyway :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
