Testing new fuel setup on the Galant, also setting up rear end. Was wondering if anyone else was testing?
if you mean the east coast nationals test and tune ont he 27th of august, then yes i am testing that day. we believe if the new torque convertor is ok i should be looking at a 10.2
29th of august is a tuesday
Excellent, did you end up changing the box aswell?
Have heard that the Port Kembla Cup will be contested again on sunday, Momo with 8 sec Rotary is testing, Jigga with 9.1sec LC torana, Kon with 10.3sec aspirated Lx hatch, All these guys are from Port Kembla, all mates sort of, funny to watch, they gee eachother up something fierce, funny. Good to see a lot of local boys having a crack. East Coasts should be big. Wonder if any Lines will be running in Super Street?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
