  • Replies 184
Posted Images
my ex is a single skyline owner, 32 gtst auto.... my ultimate dream girl would have to own a skyline, and not a busted up one!
haha thats getting your priorities right
I know a few girls on the sunshine coast who drives skylines, one in a na r33, another two that drive r32's, also know a girl who has a nuts s15, and my ex drives a MY00 wrx.. no loss there :D ohh and another girl i met a week ago that drives and drifts her r32 that lives in brissy w00t!
HA ha ha watch this :D ..................
ALL SKYLINE OWNERS ARE GIRLS!!!!!!
HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA
*Runs away laughing manically*
HA ha ha watch this :) ..................
lol what a stooge... silvias are for the soft cocks who cant handle a RB!!!
:D
:angry:
but.......
just trying to get back ON TOPIC!
he he he and as always
silvia = Soft Cock
silvia + RB = Soft Cock with Viagra! = ME!!! ha ha ha
Skyline = All balls and no Cock!! (has the goods but cant deliver it HA HA HA)
silvia = Soft Cock
shouldnt it be>
silvia = no cock
silvia + rb = just knob no shaft
Skyline = to much cock an balls to handle.
Dave you suck!!!
:P
i know a soon to be single girl who owns a R32?
ha ha ha My Brothers Girl Friend!!!
you notice when ever a chick owns a nice sports car, in this case a skyline ,the boyfriend tends to drive it more often!!
ha ha ha :(
HR32_GTS-T
nice work, you need to split up the catergories a bit more
Silvia + Ca18 = NO COCK
Silvia + Sr20 = Soft Cock
Silvia + rb20/25 = Soft Cock + Viagra
Silvia + RB26DETT = OMG :laugh: 2inchese from the ground COck!!
Skyline GTST/GTT = Big Balls little Cock
Skyline GTR = :laugh: Porn STAR!! (i love GTR's saving up for one or at least an rb26 for my baby :D)
and last but not least
Common whores' = just Fu{Ken Cock Heads!!!!!!!!!!!!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
