For those who have R32 GTS-t, I was told some R32 GTS-t were delivered with smaller rear disc (but I was guessing this maybe the non-turbo), so please measure your R32 rear discs and tell me if you have the:
- 266mm disc 7690S slot or 7690G dimpled, or
- 297mm disc 908S slot or 908G dimpled (same as R33 gts-t rears)
  • Replies 245
Posted Images
OK GUYS...
They have branches in every major capitals and you can pickup at your local branches, or I can ask them to quote on shipping to each state.
For the time being, have a look at the spreadsheet and let me know if there is any issues.
All of you in the spreadsheet list should have received a pm from me containing the same info regarding part no, size and discounted price. So if you cannot open the spreadsheet, don't worry it's not the end of the world!
And for the person in this forum who asked if he can buy a blank disc for his car, unfortunately the answer is no. You have to buy a whole crate of blank disc if you really want.
I will keep this group buy on until Friday then while I get the shipping quotes and then we'll start finalising payment terms. For those who have not given me their Name & Delivery Details (in case they need to ship out), please pm me with your details. Your name & address will not be disclosed to any other 3rd party not related to this Group Buy activity.
Regards,
Rianto
... and it is ok to cancel or change your mind at this stage. i.e. if you want to upgrade to grooved / dimpled rotors or downgrade to slotted only for any reasons, i.e. price.
OH AND THOSE WITH R32 GTS-T i am sure your rear rotors are the same with R33 GTS-t but please can you double check if your rear rotors are 297mm or the smaller 266mm (I was guessing this is non-turbo) - it is best to be safe now rather than sorry later if it's too big to fit your caliper.
Your doing a great job so far, keep up the good work. :(
one thing though, if the front rotors on an r32gtst are 280mm diameter, you wouldn't think the rears are going to be 297mm, i'll try and measure mine tonight because the prices are that good i will probably end up buying fronts and rears :ermm:
edit: ok well i checked last night and the rears are in fact 297mm.
Edited by R32gts-t
It still make sense to have slightly bigger rotors at the rear for R32 gtst as the RB20 is a lot lighter than RB25 and it's a RWD.
When I cross-check with DBA catalogs, R32 GTS-t are listed as 280mm fronts and 297mm rears.
If any of you prefer pickup there are locations as follow...
http://www.rdabrakes.com.au/contact.htm
Just let me know which one you prefer, pm me, please it's hard to track replies over 5-6 pages of thread here.
Curious as to when payment is due for this? and Account details etc.
Can you get ER34 GTT single turbo front slotted rotors
These are 310mm, not the same as R33 GTST as the RDA listing suggests
If you can confirm they can supply them, I will have a set
Thanks
according to DBA catalog R34 GTT can use the same front 296mm with r33 but RDA did say there are some 310mm which is harder to get, I will ask again.
how about a set of fronts (slotted only, no dimples please) for a BNR32 GTR. They are 296mmX32mm?
thanks. :laugh:
Yes, they are 296mmx32mm - $<<price removed pm to GB members only>> GB price incl GST.
shozbot, which one u're after, I'll let u know. a few ppl have probs with the zip file but others dont.
this forum don't allow me to upload excel.
sorry I had the . and the ? the wrong way around! I know they are 296X32 I was just making sure you got the right ones!
Please put me down for a set. :O
324 x 30 front and 297 x 18 rear both slotted & dimpled. Are they the ones that are "gold passivated" ?
Thanks
What i know here is 7701S fronts (324mmx32mm R33GTR) and 908S rear (R33 GTS-t 297mm) if that's the one you're after 7701S = $<<price removed pm to GB members only>>, 908S = $<<price removed pm to GB members only>>, all group buy prices including GST.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
