rob123456 Posted August 20, 2006 Share Posted August 20, 2006 (edited) Jst bought myself a cool R33 GTS25-T. I'm wanting to spead around $5000 - $10000 to a achieve around 250kw - 300Kw at the wheels. The car is completly stock and i'm wanting to use it on the road as well as one the track. Could somebody please give me some advise on what I should be changing, what brands I should looking for and also where I can go in Australia, Victoria to tune my car. If you have the same model as me and also have a similar power output please tell me what ya did. Cheers Edited August 20, 2006 by rob123456 Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/ Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 (edited) How bout you start by telling us all what mods the car already has and the reason why you want 250-300kw as there is a massive difference between those figures. Then we can tell ya what ur gonna need... Edited August 20, 2006 by FSTR32 Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423555 Share on other sites More sharing options...
paulr33 Posted August 20, 2006 Share Posted August 20, 2006 as i posted in the other thread stock gtst + front mount $800 + exhaust $1400 + ecu $900 + heavy duty clutch $1200 + hiflow turbo or gt-rs or gt2835 ($1900 to $2800) + airflow meter z32 $300 + fuel pump $300 + injectors $600 + cold air intake $300 + boost control kit for ecu $300 + tune $500 + suspension work $1200 total $10,300 should net you somewhere from 250rwkw to 280rwkw Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423592 Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 as i posted in the other threadstock gtst + front mount $800 + exhaust $1400 + ecu $900 + heavy duty clutch $1200 + hiflow turbo or gt-rs or gt2835 ($1900 to $2800) + airflow meter z32 $300 + fuel pump $300 + injectors $600 + cold air intake $300 + boost control kit for ecu $300 + tune $500 + suspension work $1200 total $10,300 should net you somewhere from 250rwkw to 280rwkw f*k the AFM off if he's gonna run stand alone ecu Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423605 Share on other sites More sharing options...
paulr33 Posted August 20, 2006 Share Posted August 20, 2006 why would you? afm is the best way to measure air coming into the engine. with a map sensor you'll actually loose tuning points Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423612 Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 why would you? afm is the best way to measure air coming into the engine. with a map sensor you'll actually loose tuning points Not what a credible source has told me Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423616 Share on other sites More sharing options...
mickr33 Posted August 20, 2006 Share Posted August 20, 2006 Hey Paul. Just a quick question. What injectors can i get for $600 and where from. Car: R33 GTST. Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423621 Share on other sites More sharing options...
paulr33 Posted August 20, 2006 Share Posted August 20, 2006 your source is incorrect, there is no way a map sensor can offer more load points than the same map driven by an airflow meter. have a read of http://www.skylinesaustralia.com/forums/in...howtopic=122642 Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423628 Share on other sites More sharing options...
R31Nismoid Posted August 20, 2006 Share Posted August 20, 2006 as i posted in the other threadstock gtst + front mount $800 + exhaust $1400 + ecu $900 + heavy duty clutch $1200 + hiflow turbo or gt-rs or gt2835 ($1900 to $2800) + airflow meter z32 $300 + fuel pump $300 + injectors $600 + cold air intake $300 + boost control kit for ecu $300 + tune $500 + suspension work $1200 total $10,300 should net you somewhere from 250rwkw to 280rwkw Spot on, and thats without labour costs Although injectors are around $900 Clutch around $1000-$1200 300rwkw doesnt come cheap 250rwkw is far more affordable Definately stick with the AFM. For those that think they are a restriction or a hinderance, 369rwkw with a Z32 AFM would say otherwise Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423629 Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 Hey Paul. Just a quick question. What injectors can i get for $600 and where from.Car: R33 GTST. Nothing half decent unless your gettin dodgy ones. Most decent ones eg nismo are about 200 bucks each arnt they Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423633 Share on other sites More sharing options...
aquariuz6 Posted August 20, 2006 Share Posted August 20, 2006 Are GTR Injectors are a straigh drop in a r33gtst? Are there any differences between GTR 32,33,34 injectors? Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423636 Share on other sites More sharing options...
paulr33 Posted August 20, 2006 Share Posted August 20, 2006 try nismo 550's from nengun.com or you can get s15 jdm manual 480cc injectors you should able to get set for around that price. yeah perhaps my injector price was a bit too low. say $800 for a new of newies then. gtr injectors arent a direct fit, you need to modify the injector driver or something (cant remember sorry, its in the tutorial section) Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423637 Share on other sites More sharing options...
R31Nismoid Posted August 20, 2006 Share Posted August 20, 2006 Nothing half decent unless your gettin dodgy ones. Most decent ones eg nismo are about 200 bucks each arnt they Nismo 550cc injectors are not $1200 at all. I paid $900 landed for 740's back 2 years ago. Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423638 Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 (edited) "Definately stick with the AFM. For those that think they are a restriction or a hinderance, 369rwkw with a Z32 AFM would say otherwise" Quote by the Wise Nismoid Is that all? love to see the dyno sheets for that one nismoid Edited August 20, 2006 by FSTR32 Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423645 Share on other sites More sharing options...
Cubes Posted August 20, 2006 Share Posted August 20, 2006 You have a little to spend. A rough price... As a basis you'll need. Buy from Japland.. $0330 - Fuel pump $0700 - Injectors $1000 - ECU (PowerFC) $0400 - PFC Boost Kit $0800 - FMIC Kit $0050 - Catch Can $0550 - Clutch $0330 - AFM ------------------------- $4160 Now you have to pay some one to fit the parts if unable to do so your self. Your also going to need a decent preferably 3.5" exhaust, unsure what they are worth. You also need a turbo. Something along the lines of a GT30. You 'should' be able to get away with it for 10k. And thats the motor/performance side of things only WITHOUT Labour and Tuning costs. Budget 15k for 300rwkw or 10k for 250 mayybe 270rwkw. Now you need suspension and brakes. http://www.nengun.com and http://www.gktech.com.au Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423648 Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 Bit of an emphasis on "ABOUT 200 bucks"...was an estimate smart ass. Bit more realistic than 600 LMAO Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423651 Share on other sites More sharing options...
aphid Posted August 20, 2006 Share Posted August 20, 2006 (edited) how about before you offer advice you actually read up and get half a clue what you're talking about before you decide to post up shit.. i'm sorry if i'm being overly harsh but i can't stand people with no idea on a subject yet want to force there oppinion onto others. Is that all? love to see the dyno sheets for that one nismoid Edited August 20, 2006 by aphid Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423653 Share on other sites More sharing options...
HypeR33 Posted August 20, 2006 Share Posted August 20, 2006 300rwkw doesnt come cheap250rwkw is far more affordable Thats right...if you are aiming for 300rwkw $10,000 wont be nearly enough!! Especially from stock. Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423656 Share on other sites More sharing options...
R31Nismoid Posted August 20, 2006 Share Posted August 20, 2006 "Definately stick with the AFM. For those that think they are a restriction or a hinderance, 369rwkw with a Z32 AFM would say otherwise" Quote by the Wise NismoidIs that all? love to see the dyno sheets for that one nismoid Better yet, you can even see the video and look at the nice telly screen of it. How good is that eh? Stuff having a sheet, live video recording is a joy. http://skylinesaustralia.vidiac.com/recent...a697e4dad6e.htm That also includes a backup run of 358rwkw with a bit less timing. Safe to say there is nothing wrong with an AFM based car at all. Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423660 Share on other sites More sharing options...
FSTR32 Posted August 20, 2006 Share Posted August 20, 2006 Um by the way...we still havn't established what the car actually already has???he may have half the stuff that paul 33 has listed so in that case...where could his extra money be better spent? a better turbo perhaps or maybe a bit more tlc to drivetrian or suspension in order to put this "250 - 300kw's" to the ground Link to comment https://www.sau.com.au/forums/topic/131032-how-2-get-250kw-300kw-at-the-wheels-with-a-r33-gts25-t/#findComment-2423666 Share on other sites More sharing options...
