i just got my r33 back from having the water pump and timing belt replaced
now the car is making a whiny rattling noise that was never there before, its worse when its idling and just sounds like its running crap
was thinking maybe they did the tensioner too tight or something?
anyone got any ideas? and could i be doing any damage to the engine driving it like this? :(
https://www.sau.com.au/forums/topic/131393-just-replaced-timing-belt/
Theres not a lot to chose from for bearing noise, cambelt tensioners or alternator/powersteering pump/air con. You can rule out the latter by removing the appropriate belts and seeing if the noise is still there or by listening for bearing noise on each unit.
Chances are it is the cambelt tensioners if the cars done reasonable kms.
Before you got the belt replaced it would have been stretched making the load that is on the cambelt tensioners less and hiding any wear.
Now that you have a tight new belt and tensioners reset there will be more force on the bearings which will show up as a rattling noise if the bearings are on their way out.
And just to add, never had any probs with GATES belts, they make pretty good belts, Nissan don't make their own anyway.
Timing belt? Mine whined a little bit after replacing the idler, tensioner, and belt. (all stock replacements).
It might have been tight, but in the first month i'd imagine that the belt would slacken off a bit, and you'd have to retension it. Mine has smoothed out and is fine now (4 months since change).
Only other thing that comes to mind is if they didn't do the tensioner up properly... the belt will slap against the cover, and whine as it slips past the bearing.
Remove the top-half inspection plate, and check that the belts seem really tight.. maybe even shine a torch down there to check it.
is it like a high pitched noise? (like its there when u start it, and when u press a bit of gas or if ur stationery) if it is, then maybe the belts are a bit tight - I had the problem when mine was changed - its a quick fix 15 minute job
Take it back.
Did you get tensioner and idler changed when the timing belt was done?
It may be air-con tensioner bearings or others, but there should be no noises.
hmmm, well i bought the parts and only got a new belt, so id have to check that out..
Its probably a gates belt! ask them what kind they used. gates belts are crap! stick to genuine. That is if all your other cam gear is stock. who did it?
yeah all stock and mmm yes it is a gates racing belt, the blue one...
thanks for that, well its done 113000, so yeah will suss it out
You might have a baby caught in the belt, check under the timing cover for small fingers or toes.
LOL...quite the comedian
Hey! I saw your car at RE the other night when I went to pick up my car! Rays a good guy, he will fix up the problem.
hey, yeah he is, i actually asked about it after i started it up while i was still there and heard the noise, he said it should be fine and could last till next service, but yeah i just dont want my car sounding like that for the next 5000kms so id rather have it fixed, watever it is and yeah dunno wat to do yet
Sounds like the belt might just be a bit tight - its often the case with the new belts (im assuming here its the same problem that I had). It would die out in a couple of months - but it is quite embaressing driving a hot car when it makes a noise like that.
Edited by emsta2003
yep it is kinda high pitched (and very annoying) and its worse on idle/stationery and yeah my initial thought was its too tight...mite be easy but i cant fix it myself though cos i have no idea wat im doing lol
i had a look and the belts are like super tight, i cant twist them at all
if its to tight (very common mistake) it makes a wir wir wir wir noise
if its to loose it makes a flap flap flap noise.
the belt tension adjustment needs to be as follows.
with the belt on and the tensioner not done up...wind the motor over to take up the slack in the belt. then simply lock off the tensioner. (thats what the spring is for lol :) )
hope that helps :)
Sounds like what I had after my timing belt was changed - its a 10-15 min job. Main thing is its nothing serious
if its just loosening the belt a bit, it can be done without having to remove the whole front. There is a cover underneath the car which has to be removed (can be done while the car is on the hoist), then its just a matter of using a spanner or socket spanner to adjust the belt.
Well, thats what happened to mine anyway...and there hasnt been any troubles so far...
I think your confusing the aircon belt with the timing belt, or at least one of the other two that run off the harmonic damper. The timing belt is located behind the timing covers which do need to be removed inorder to adjust the one tensioner which is also behind the covers.
The only idler that can whine/wir/squeel is the aircon idler which is obviously outside of the covers and sits below the aircon compressor.
and whoever said gates belts are shit is a moron :(
Edited by r33_racer
Ah - that might be it - yeah they didnt remove anything when they readjusted the tension..:(
  • 1 year later...
k gates racing timing belt does make noise but when mine got done it was found that 2 days later somewhere i have a dry bearing when it starts up it make a really scary grinding noise then goes no probs after 2 secs but as it off the road no big worries atm being fixed soon and yeah they "rigoli" over tension the belt
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
