  • Replies 51
Posted Images
if you want to shorten in to get the best response, change to a top mount cooler. you will cut a fair bit of piping out, but will get major heat soak.
also for those interested in power loss from aircon, at a dyno comp i was turning off the aircon and the dyno guy started telling me about a toyota coaster (small bus) that the aircon took 17hp out of the motor. i know cars don't take that much, but we used to have a subaru sports wagon and it made a huge difference (but it was a really gutless car. 62kw at the flywheel, and weighed about as much as a skyline). i'd say it'd probably take about 5hp.
i just compared the v mount setup to the standard setup, and the piping length difference is simple due to the tighter angles on the cooler. if you tightened the angles of the bends on the cooler posted by EXAUNV then you would get the same affect. also using the aftermarket plenum gets rid of some piping, but makes up for it in extra plenum length.
there is an illusion to that with aircon, without aircon dyno. the illusion is that the aircon run was done second, and as most people know, turbo cars generally dyno the highest on the first run due to heat soak. and it was done in feb, which isn't the coldest month of the year. my mates built silvia lost a about 10hp every run due to heat soak at a dyno comp on a hot day.
Edited by mad082
And if you notice a throttle difference with an extra bend or two, i'll hand you a medal :(
Cause you wont notice it at all IMO.
Im with you on this one. As long as the piping is kinda right in the first place...i dont think there will be any noticable difference.
...but the overall idea is to have the radiator sitting on a 45 degree angle and your intercooler sitting on a 45 degree angle, the overall the advantage is that the pipes are shorter, and neither your intercooler or radiator are getting less air flow. The disadvantage to this setup is heat soak.
But they do get less airflow, the air has to either go up through the intercooler or down thru the radiator. It does mean though that the lsioghtly heated air that has passed through the intercoole risnt used to cool the radiator. But thats not a biggy anyway as the radiator can be sized accordingly.
The main reasons in racing are that you get better weight distribution as ther heavy (full of coolant) radiator sits lower in the car. It also helps in race cars as when 'rubbing is racing", well with the IC behind the raditor support panel it is not going to be punctured meaning loss of power.
Frankly im surprised that ppl who are concerned about this do not grab an STI cooler. Weld some sheet and baffles over it. Top mount the thing and run a water to air intercooler. You get stable inlet temps. With water you get the chance to actually lower the inlet temps below ambient (ICE BOX etc) which you can do when using ambient air as a coolign medium.
Depending if you clock your turbo housing correctly, you basically end up with a single bend and less then 5" of cooler piping. That woudl be a dramatic enough a change to actually made noticable differences when driving the car.
There are of course disadvantages, being the weight of pumps, water and the reservoir. Introducing a pump that can fail, and puts an addiional load on your electrics...but i think a top mount water to air cooler is about ideal for a road car that gets raced from time to time.
...oh and ithat engne bay pic a 350Z??? Why on earth would you rip out a gem of an engine to fit an SR20??? cRaZy Japs :)
Many valid points.
P.S the engine bay is my 4 door R32 (dedicated drift car), I wish it were a 350z.
EDIT: you obviously mean the other engine bay.. my bad :(
Greg
Edited by EXAUNV
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
