  • Replies 117
And don't forget guys, this car does a 10.04 sec 1/4 mile according to the owner. It was published in this month's Autosalon magazine, full write up on the car....
Was at Dutton Rally at Sandown and overheard the owner claiming it had done a 10.04 sec 1/4 mile in Japan.... :D
Is it just me or does anybody else find that hard to believe???
500ps + 1500kg = 10.04??? :D
Oh, and why didn't they say what mph it reached??
Still, I'd buy one..... :laugh:
Was at Dutton Rally at Sandown and overheard the owner claiming it had done a 10.04 sec 1/4 mile in Japan.... :nyaanyaa:
500ps + 1500kg = 10.04??? :dry:
Still, I'd buy one..... :sleep:
Everyone talks it up... just some go further than others...
It has a lot more than 500ps :/
Really?? Has it been modified beyond Nismo Z-Tune specs?? Or is Nismo underrating the power??
Here's the specs according to Nismo: http://www.nismo.co.jp/Z-tune/data_e/6.html
They also claim it weighs 1600kg, I thought it would have been 1500kg with all the carbon fibre.
Then again all the diff/trans coolers would add weight...
So blacksx, how much power has it got?? I'm curious... :)
Was at Dutton Rally at Sandown and overheard the owner claiming it had done a 10.04 sec 1/4 mile in Japan.... ;)
500ps + 1500kg = 10.04??? :)
Still, I'd buy one..... :(
I don't find it hard to believe, the data was recorded on Nissan's own test course so I'd be happy to believe it were true.
If it came 4th, who came 3rd, 2nd, and 1st?
P.S. dream car there...
Team Outright
1. Mitsubishi Lancer EVO VI
2. Whiteline EVO VIII
3. Mitsubishi EVO 3
The Z Tune actually scored enough points to place 2nd outright however it was docked points by the officials for some "circular antics" in the pits/carpark
The proto version would run 10,s but the one;s they sold would no way go 10.02.
In plenty of best motoring vids the Proto version is way faster/quicker and looks like a 10 sec car but in videos with the street version the car no where near moves, revs or sounds quick enough for a 10, It was struggling to catch a new corvette down tsukuba and didnt catch it not to metion the S205 Sti that was in front of them both.
See for yourselfs.
GTR R34 Z -Tune Proto vid at Nurburgring--
http://www.youtube.com/watch?v=735zkR7xTgw
GTR R34 Z-Tune 500ps production model-
http://www.youtube.com/watch?v=-emo2QIMmeY
There is another video of the Proto at Nismo festival Fisco and it came 3rd the vid isnt on Youtube anymore.
1st was ATTKD BNR34 GAIAX
2nd Mines BNR34
3rd Z-tune Proto
4th MCR BCNR33
The proto had closer to 800ps no cat converter and more agressive tune that would go 10.02, the production one would of never kept up with the mines GTR
Edited by nismo 400 R N1
See for yourselfs.
2nd Mines BNR34
3rd Z-tune Proto
4th MCR BCNR33
Thought so, the specs just don't add up...
The proto sounds like it had no restrictions like the production model has...
Thanks for the info!!!!
I can't say for sure if this Z-Tune could run a flat 10 or not.
However what I can say is that in the Dutton Rally Vic this year the Z-Tune on the Airport run ran a best time of 15.46s.
It should be noted that Mark Berry's best time for that event is 15.76s and Mark has run a 10.4s 1/4 mile. So the Z Tunes drag time was under Marks time and Marks 10.4s was done on R Comps.
Having competed against the car there is no question it's a decent bit of kit.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
