Here's a quick rundown of the day:
NismoR34 - R34 GTT with pod, cat back and boost
182.0 rwkw @ 7100 rpm
Jet-33 - R33 GTStApexi S-AFC, Blitz Access ECU, Blitz BOV, 3" zorst, POD, Turbosmart boost controller @ 14psi peak holds 11 psi
179.9 rwkw @ 6900 rpm
RUS - R33 GTSt Mods ???
183.2 rwkw @ 6800 rpm
TUFR33
MUCK
riggaP
Adzmax - R33 GTSt Mods ??
164.9 rwkw @ 6700 rpm
INASNT - 400rwkw Supra, apprently INASNT was 'having us on' and couldn't deliver :D
DJ_L3ThAL - R33 GTSt, SAFCII, Boost, leaking BOV (now fixed), possible faulty coil pack also
162.4 rwkw @ 7000 rpm
Jamezilla
Adz - My old R32, unfortunately he slept in :P
Matty - R32 GTSt, who also 'slept in'
R31Nismoid - Unfortunately when fitting a boost controller I discovered the R31 had a faulty fuel pump which will be replaced shortly.... expect some big numbers soon
Al - R33 GTST, Wolf 3D ECU, 12 psi boost
172.4 rwkw @ 6400 rpm
R32PWR - Mental R32 GTSt RB27 with twin HKS 2835R's, unfortunately during "testing" on the previous thursday night full boost in second managed to snap the RHS axle... But beware....
Ronin 09
RedlineGTR
Meggala - R32 GTST, Pod, Zorst, 14 psi Boost, Dr_Drift ECU
148.0 rwkw @ 6800 rpm
Ben from BMT - 180SX, SR20, Dr_Drift ECU (not tuned yet), 17 psi boost peak holding 12 psi, FMIC, zorst, filter
155.3 rwkw @ 6000 rpm
Mutex - Stock as a Rock R34 GTT
161.1 rwkw @ 7000 rpm
https://www.sau.com.au/forums/topic/13156-dyno-results-29303/
ooooooo i c.
1fitty! hmmmm.. damn it i want an extra 8rwkw!
can u ask benny it will be for stainless 3" dump and front pipe?
im thinking of not bothering with the cooler just yet and get these bits done first.
Thanks again Doc!
One thing has got me curious though: did the guys keep turning off the TCS after each restart of engine?
TCS always comes back on after ignition / engine shutdown!
Perhaps this explains why increased boost and also using your BV didnt make a difference?
I only turned off TCS the first time...
Originally posted by nismoR34
Thanks again Doc!
Don't really know actually?? I'm pretty sure they didn't turn it off after restart.... hmmmm that will have to be an experiment for my new dyno??
Sounds like a plan to me :(
What brand dyno is it? Locality [near Essendon or ?]?
I am pretty keen - though I am not expecting to get much more than 182 in current form... I will probably wait until after I have done some mods. Looking at finishing off exhaust soon.
It's a Dyno Logic, I've researched thoroughly and believe this is a much better product, and has many more features than the more common Dyno Dynamics. The new premesis will be in Heidelburg.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
