Just wondering if you guys know if the stock 17" x 9" GTR wheels with 245/45/R17 will fit on a S14 200SX? My stocko wheels are the Nissan 16" alloys. They have 205/55/R16 rubber on them. Im pretty sure the offsets should be alrite, just wanna know if theyre too wide. Any help or links to this topic would be appreciated. Cheers, Paul
Edited by Paul B
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/
the only reason i know they fit is because there is a someone at heasman steering in sydney with a white s14 r33 gtr wheels. lowered and looks good.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2437350
17x9 on my S14 needs to be +20 at the front to clear the coilovers.
On the rear 245/40R18x9+22 fit without any spacers
This is what an S14 (not mine) looks like with +30 offset, 25mm spacers all round. = +5 offset.
Only a fender roll is required to fit this. Tyres are 215/40 front, 215/45 rear.
Wheels are stock R33 GT-R wheels which are 17x9, the narrow tyres allow the nicer fitment
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2442274
^^^ it's not that they will sit in, it's that they will hit the strut/spring, i have them on my s13, i have 3omm spacers all round, i could probably get away with no spacer on the rear but definatley needed on the front.
225 is about as wide as i can go with the spacers fitted, 215's may fit without the spacers... great looking wheels you should put a pic up.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2444122
They just bolted onto my old 200SX fitted with 235/45/17 with 2.5 degrees of camber.
I only had OEM style Nismo replacment struts and they cleared the shock body and spring seat fine.
Looked pretty understanded on white too.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2460826
did u have spacers fitted on yours???
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2461118
Hey there,
I have a set i am selling with 245/45/17 tyres Hankook Ventus 104's 95% Tread.
Look in the parts section.........
They do look good on a s14 I have to admit.
Although i think they would look better with rolled or flared guards.
Cheers
Tekin
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2461375
frankxiyu pm'd me, but for everyone else - no spacers were fitted to mine, but they did rub the plastic inner guard a little,but nothing a stanley knife couldn't fix.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2463634
just an update for the information,
the R33 GTR wheels which have 245 tyres went on the S14A today with NO spacers, and we did not roll the guards....stock suspension, which means once coilovers are done, even widers tyres can go on....
it is doable, and the car looks awesome....problem solved.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2502142
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
