Just wondering if you guys know if the stock 17" x 9" GTR wheels with 245/45/R17 will fit on a S14 200SX? My stocko wheels are the Nissan 16" alloys. They have 205/55/R16 rubber on them. Im pretty sure the offsets should be alrite, just wanna know if theyre too wide. Any help or links to this topic would be appreciated. Cheers, Paul
Edited by Paul B
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/
the only reason i know they fit is because there is a someone at heasman steering in sydney with a white s14 r33 gtr wheels. lowered and looks good.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2437350
17x9 on my S14 needs to be +20 at the front to clear the coilovers.
On the rear 245/40R18x9+22 fit without any spacers
This is what an S14 (not mine) looks like with +30 offset, 25mm spacers all round. = +5 offset.
Only a fender roll is required to fit this. Tyres are 215/40 front, 215/45 rear.
Wheels are stock R33 GT-R wheels which are 17x9, the narrow tyres allow the nicer fitment
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2442274
^^^ it's not that they will sit in, it's that they will hit the strut/spring, i have them on my s13, i have 3omm spacers all round, i could probably get away with no spacer on the rear but definatley needed on the front.
225 is about as wide as i can go with the spacers fitted, 215's may fit without the spacers... great looking wheels you should put a pic up.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2444122
They just bolted onto my old 200SX fitted with 235/45/17 with 2.5 degrees of camber.
I only had OEM style Nismo replacment struts and they cleared the shock body and spring seat fine.
Looked pretty understanded on white too.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2460826
did u have spacers fitted on yours???
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2461118
Hey there,
I have a set i am selling with 245/45/17 tyres Hankook Ventus 104's 95% Tread.
Look in the parts section.........
They do look good on a s14 I have to admit.
Although i think they would look better with rolled or flared guards.
Cheers
Tekin
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2461375
frankxiyu pm'd me, but for everyone else - no spacers were fitted to mine, but they did rub the plastic inner guard a little,but nothing a stanley knife couldn't fix.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2463634
just an update for the information,
the R33 GTR wheels which have 245 tyres went on the S14A today with NO spacers, and we did not roll the guards....stock suspension, which means once coilovers are done, even widers tyres can go on....
it is doable, and the car looks awesome....problem solved.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2502142
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
