  • Replies 183
Posted Images
ok all Long wang vids now posted
(this should be everyone in group 2)
http://www.youtube.com/profile?user=emts42
Good effort, well done. :ermm:
Any chance of grabbing the Evo vid if its not too large please?
Who hosted them last couple of times?
http://sau.tharaka.net/
Ask them nicely ;)
If anyone needs hosting, PM me and I'll send you the FTP details when I get home (don't have them here at work)
There wont be any size or bandwidth restrictions
Saff if you can hold out for a couple of days we'll see if can get some ftp spac, as i've got a couple more of you onj the skid pan and a few from the battles
No worries mate, sent you the email addy anyway.
Thanks dude ;)
What a champ, upload them to darK's site......
al you've ditched the wing now yeah?
if so yeah there's one of you from battle 2
Yep.... Didn't have the wing on that day.
Only use it for track days....................... which to date has been NEVER :sick:, or occationally by popular request :(
Well Folks big thanks to darK, got the FTP last night..
spent an evening uploading..
so here you go all the clips in much better clarity
http://sau.tharaka.net/DECA_Aug26/
Awesome, thanks heaps mate, and thanks to darK for providing the space >_<
