Hey guys,
I know it aint a skyline... nor is it even a car :D but thought someone might want it.
17k on the clock.
4500?? make an offer
(posting on behalf of friend... will post specs when i have em if anyones interested)
http://www.suzukicycles.org/RGV-series/RGV...250-Gamma.shtml
all specs on the bikes can be seen here... its a 1991 model
heres a pic
https://www.sau.com.au/forums/topic/13194-not-a-car-rgv250/
heh... maybe i should start a "2 wheels" forum.. :D
inark - kinda interested, but if i get it, i'll have no fiance, so i am just weighing that up at the moment... :rolleyes:
https://www.sau.com.au/forums/topic/13194-not-a-car-rgv250/#findComment-254065
Originally posted by EnricoPalazzo
Derr a NSR is a 250 and it kills a rgv
NSR 250SP 1991 [email protected]
RGV 250 1991 12.90@108mph
so i dont know where ur getting ur info from.
https://www.sau.com.au/forums/topic/13194-not-a-car-rgv250/#findComment-254139
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
