Hey,
Just wondering if i've had my chain pulled here.
I recently just put a nice Stereo in my R33 Skyline, Unfortunately there is noise coming through the speakers. I corrected this through a Ground Loop Isolater (Headunit -> Isolator -> Amp via RCA).
Whilst looking for one, i was advised by a car audio place that my amp should already clean this up, however the guy who did the install (and is held in reasonable regard around here according to a SAU ACT member) mentioned that it was a particular problem with R33's and BA Falcons.
Who is telling the truth? should my Cadence FX500 5 channel amp filter it out? or are R33's a noisy bugger and require more?
Is there a better (and cleaner sounding) solution than the $15 part i bought from AutoBarn?
Cheers,
Geoff
https://www.sau.com.au/forums/topic/132518-ground-loop-isolators-amps/
Hey,
Cheers,
Geoff
both are VERY noisy cars - though if you do the wiring correctly that wont be a problem. what you have is a quick fix and works. it will also roll the VERY low bass off quite sharply.
so of the amplifiers have better input stages than others but to my knowledge none of them have inbuilt RCA chokes. (on th PSU they do.)
What would your suggestion be to rectifiy this?
I only have the Ground loop Isolator on the Front/Rear Channels atm, the Sub is unfiltered.
could be your head unit.
i had a really bad alternator whine when i put my stereo in a while ago (pioneer HU, Alpine splits and 6*9's and cadence 4 channel) tried every thing to get rid of it in the end sold the pinoneer HU and brought a good Alpine one and the noise was gone don't know why ?? but i;m happy
Edited by Spook33
I just spent ~2100 on the stereo, the head unit is a middle-ish range JVC KD-G725 unit. I'm quite attached to the USB input to be honest, if i can get the noise filtered properly, i will do magical star jumps.
if you can pull the rears off and stick a shorting plug in place then move the isolator to the sub channel as a temp measure. if it works buy another one. to do it properly would require a TOTAL strip and rework.
unlikely but possible. only way it could do this would be if the amplifier earth was loose. that in turn would destroy the earth tracks on the unit.
try what I suggested first.
  • 3 weeks later...
JVC deck actually.
that being said.
the problem is intermittent. I can't put my finger on how to get it to make the noise.
Example. Roughly about 23-24 on the volume will be enough to drown out all but 5000 - 7000 rpm of exhaust engine noise.
When it is behaving, i will not hear the whine after about 4 (very quiet) - sometimes i can't hear it at 0.
When its usually being annoying, i will hear it till about 14.
When its absolutely f**ked i will hear it till 27 - 28.
I have a Stinger GLI, should i get that earthed (the shell) as well? The system sounds awesome, its just that when its playing the whine - i just turn it off because it makes my head want to explode.
Edited by nsanity
My mum had this problem in her car. i rewired it to make sure the rca's where away from the power cables, that didnt make any difference. Then my dad played around with it and he had it unmounted and it wasn't doing it, in other words the metal body of the car wasnt touching the metal body of the amp and that fixed it. We ended up using velcro and mounting it to the carpet.
Good luck
you dont have a pioneer deck do you? they absolutely hate skylines!! if you have pioneer its your problem
Huh? I just installed my Pioneer deck with no noise or problems at all. Completely new wiring and all. Don't know what you're talking about. >_<
i have found an easy solution which should work, which is quite simple, simply attach a small wire to the rca's where they plug into the amp, if your not sure what i mean, the lil metal tip which goes in her hole!! then ground them, does not seem to matter if they all grounded together, solved my problem
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
