  • Replies 152
Posted Images
Had some head work when I bought it had the oversize valves and some port work but windsor engine reco's did all the machine work (ur ole stomping grounds)and head work eg new valve guides head flowing and straightning of the head ,said it was twisted and bowed got to admit the cams do turn better and faced it ,also did work on the block but I redid the ports a as big as the gaskets to finish it off
https://www.sau.com.au/forums/topic/132547-again/page/4/#findComment-2907270
Using a haltec E11v2 it was tuned to the old engine , this one has a bit more work done to it internally and to the head but the bolt on's are the same so tune won't be to far out
https://www.sau.com.au/forums/topic/132547-again/page/4/#findComment-2937991
I dont know maybe I should leave this power plant in call it cute power though I could never shut the bonnet on her my beautiful grandaughter
she likes to help popa only trouble she likes to help with a hammer arrrr noooooo :happy:
https://www.sau.com.au/forums/topic/132547-again/page/4/#findComment-2952199
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
    • Hey all, Noticed I have a hole on top of which im guessing is my transfer case/gearbox. I can see it from the middle of my firewall looking down. S1 R33 gtr Any advice or can pinpoint what this is/caused this?
