  • Replies 152
Posted Images
Stock plenum and air box.
Love it!! :)
is this an 89 model?
Dash instruments look great.
actual Dash loods good too.. has it been painted black?
Interior retrim is not what I'd do but at least it's new..
so being an 89 model.. let me know when you decide to sell it for $9K.. LOL..
very nicely built car mate.
https://www.sau.com.au/forums/topic/132547-again/page/8/#findComment-3131304
Jnr32r,
Im a drag person myself wanna get my 11second pass , though I may take it to a track day as yet dont know .
GTST
Yeah looks pretty standard under there ceptin for the shinny bits ,its a 93 model there just the plates I got from the rta ,I had a laugh about that too,yes dash is painted black as is most of the trim barring the inserts and seats ,I went with the red and black because there are so many others out there that have gone with the tans and whites and others like beige I wanted this to look fairly standard but neat and along the lines of the car as there not a great deal of red's i got to choose from that was fairly close to the colour of the car and wanted a standard material as well (I recon leather sweats to much and I hate cleaning windows I've had leather trim b4) and it keeps in contrast with the dash as well being red and black.Gee is it worth that much I was gonna sell it for less :huh: and thanks it was alot of work
Sleepyboi
Thanks mate glad you like it :rofl:
Moanie
I dont know as yet there still some probs I have to fix like the leaning out b4 I go doing anything with it at the moment just wanna enjoy driving it for the time being but if its all fixed and running right i will be thinking about it had alot of people trying to talk me into it of late
https://www.sau.com.au/forums/topic/132547-again/page/8/#findComment-3132476
Close call last night ,went for a drive upto Taree to visit a mate and do the finial stage of running in the engine was coming back and just near nabic a damn kangaroo jumped out in front of me and the car in front Damn !!!!! quick lock up and swerved onto shoulder to avoid collision with 2 legged jumping marsupial i think it attually jumped over drivers side of the bonnet since the speed limit there is 110klms I think I was fairly lucky maybe just a few stone chips from road side gravel, the amusing part about this is I traveled that road for near 10 years twice a week between Sydney and Brisbane and never came close to hitting a roo but take my toy up there just once and our native emblem tries to write me of dont they know I just finished the damn thing would someone please tell em . Feel better now had my Rave !!!!!!
Peter
longest sentence ever
https://www.sau.com.au/forums/topic/132547-again/page/8/#findComment-3132816
Hi GoldZilla
Its now a 2.1 ltr been bored 40thou or 79mm and has an rb25 crank which makes it 2108cc and thanks for the complement
Peter
That's awesome considering the displacement has only increased by 100cc - obviously you've put a lot of time and thought into the modification process!
All credit to you, you deserve it.
https://www.sau.com.au/forums/topic/132547-again/page/8/#findComment-3134321
Hi Roy
Yes, still useing the hks 40mm external wastegate on the hks manifold,I'm useing a hks exhaust I think its called a hypermax or something cant get my fat head far enough under the car to read it properly. I have a custom front pipe thats 3" with the external wastegate plumbed back into the exhaust just b4 a catco highflow cat the stainless steel barrel type bought it of BATMBL then its 3.5" through to the resinator and 4' to the barrel muffler
Hi GoldZilla
Thanks mate,my goal with this setup was in trying to get the lag time down which I think I've succeded with to an extent, which would there for bring the boost on earlier, and there would bring on the power earlier and give me a broader power base to work with.The turbo being a gt3040r is a big turbo on an rb20 at the best of times but it also has the .82 exhaust housing which I new would give me the higher end power, this is where all the porting of the head and flow honing of the cast manifold and both hot and cold sides of the turbo has helped to acheive this as it starts in positive vacume at around 2000rpm
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/8/#findComment-3135580
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
