  • Replies 60
Posted Images
This is all quite old news, it happened months ago. It was (7.81 @ 17xmph) the first meet with a new engine and turbo setup - the package definately had more in it, and has not done a meet since. I fully expect this car to go quicker than HKS did in Oz....
I recommend going to watch this - seeing/hearing it go in person is definately a hoot :P Theres no other GTR in the world currently racing that I am aware of which is going to show you solid 7 second runs.
Awesome!!!! gives me goose bumps!!!
I have to ask a question, well a couple actually.
Is this 7sec GTR rear wheel drive?? what's the go?? no smoke or spinning from the front wheels??
which prompts me to ask another question?? i've watched a few drift videos & see some GTR's drifting & only smoke from the rear??
WTF? am i missing something??
You can convert them to rwd in the 32s by pulling a fuse. R32s Im pretty sure are primarily RWD until you loose traction as well.
Hmm, mines only an 11 sec GTR & when i jump off the clutch at 8,000 i'm smokin 4 x 4 :D
i reckon he's gotta be an 11,000 man so it should be smoking from every orifice!!!
awesome car, just f ing awesome!!
would really like to know the answer as to why the Mecca of 4WD weaponry is running 7's on two??
whats the benifit?
two on street tires would be a saussage sizzle?
Drag slicks different of course, but just doesen't compute?
Most likely converting it to rear wheel drive for the burn out to heat up the tyres.
Either way i think it would still be 4WD!
Quick times but since its on Menthanol now i don't really consider it in the same leauge as HKS, GTR 700 and Keir Wilson etc. those guys are all still using petrol which is where the challenge is at.
As you can see converting to Methanol has made it very easy to dipp into the 7's
I seriously think GTR 700 will be the 1st Aussie 7sec GTR if and when it comes back!
Sorry - It IS still running a 4WD setup, and also ran into the low 8s before it turned to Methanol. The Methanol setup was the major change which got it into the 7s, and since then its got a new motor and turbo combination - who knows what THAT evolution is capable of. He's taken it to Oz to find out :O
I'm guessing you guys know that in testing at Willowbank Heat Treatments have got down to 7.73 @ 183mph? They have a reputation of systematically getting quicker and quicker - so fingers crossed the weather is good for Jamboree! >_<
That'd be the quickest run ever by a Skyline GTR in Oz - quite cool when you consider the HKS drag R33 has raced there!
it still runs an air to air intercooler also last time i checked. why i dont know but there must be some need for cooling.
a local tuner here (blue evo that runs low 8's) has said these passes arent on full power either so that shows lots of promise :(
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
