like the title says, im looking for a few parts:
Suspension
Wheel Bearing & Seal Kit
Lower Control Arm & Ball Joint
Caster Rod
Castor Rod Bracket
Stub Axle
Stub Axle Upper Support
Sway Bar "U" Bracket
Sway Bar End Link
Outer Tie Rod End
Rack End
General
Guard Liner
Front Bumper Cover
LHS Headlamp
Guard
Guard Liner
LHS Mud Flap
Radiator Support
Air Cond. Condenser
Guard Bracket
Radiator
any help would be great. cheers
Edited by nisskid
https://www.sau.com.au/forums/topic/132803-anyone-wrecking-a-r32-gts-t/
got passanger gard (gun grey, same as yours) head light, indercator an mud flap for $250 or make an offer
front bumper cover ???????? got a couple of stock front bars as well might be able to help with that one as well just pm
gday a mate of mine has everything you need he has a written off 4 door gtst minus engine and gearbox he would just prefer to sell it as a wreck though how much exactly are you looking at spending?? he might sell the parts seperately though i can let you know by friday though
cheers Paul.
hey 4dirty2 that green gemini in your sig does that belong to a kimberly????
well i have had a few quotes on the all the parts, i wouldt want to go any higher than 1000 for all the parts depending on the general condition. im going on what wreckers have quoted me for good condition/re-condition parts.
i could do an individual rough figure for each part if that would help?
yeah a rough figure would be good i've told him to come on here tonight and join up so he'll be able to let you know but he said he'd be happy with roughly a grand and basically has a whole gtst 4 door type m sitting there without an engine or gearbox just the front passenger door is crushed in everything else is good and if he doesnt get on here tonight for some reason i'll pm you his phone number
cheers Paul
on the same topic....
anyone have a good condition dash?
Mine has three splits in it.. and I want a replacement. vents not needed but would be handy.
yeah might be able to help you out with this aswell john lol its in good perfect condition from memory i'll get him to get back to you though
cheers Paul
Suspension
Wheel Bearing & Seal Kit 103
Lower Control Arm & Ball Joint 53
Caster Rod 44
Castor Rod Bracket 26
Stub Axle 56
Stub Axle Upper Support 26
Sway Bar "U" Bracket 3
Sway Bar End Link 15
Outer Tie Rod End 15
Rack End 44
Total 368
General
Guard Liner 15
Front Bumper Cover 71
LHS Headlamp 59
Guard 85
Guard Liner 15
LHS Mud Flap 9
Radiator Support 103
Air Cond. Condenser 71
Guard Bracket 17
Radiator 71
Total 497
these are just some prices ive put together with help from quotes i got from wreckers.
got a dash here as well. dont now wats the goin price on one can any one help
yeh its kimothyz car. how u now her
i painted that gemini for it's last owner fair cheap , came out ok for a gemi i suppose
CHris,,,
she's one of my mates little sisters friends and she's from blackwood aswell i know or know of most people in blackwood and nisskid im still waiting for my mate to call me back
Paul.
CHris,,,
not to bad at all
Paul.
yeh she told me today kimz older broz friend.
yeh uv rpob seen me an other mates up in blacky hang at skaty sum times or with the old st johns guys
yeah dude i dont really remember you from skatepark but i remember when i saw boco at dominoes i was with james angrave, and my mate daves joining sau either tonight or tomorrow sorry bout the waiting
Cheers Paul.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
