Hi skyline friends .I just went to ebay I saw R34 gtr low kms and only $16800 includeing compliance .I think too good to be true.Maybe someone try to rip people that love skyline off.Or could be true price but I doubt it it can't be true.Please becareful .Any one can help to investigate thanks.Or can you belive that price for r34 gtr $16800 ready for register??????? :)
https://www.sau.com.au/forums/topic/133069-r34-gtr-on-ebay-for-17k/
yes, I saw it...and actually asked the seller a question to check out his response...scam obviously...below was his reply email.
Hi,
Thank you for contacting me about the 2000 Nissan Skyline GT R34 - Super Car
(Blue, 40,000 Km, Clear). The car is still available for sale.
About the car: excellent condition, no scratch and hasn't been involved in any accident. The motor runs perfect.
This model is equipped with the following:
2600cc with turbocharger, Signal Auto Carbon Muffler, BLITZ SUS POWER Air Cleaner, ARC Intercooler, HKS EVC, Power: Tuned up to 400hp
I am the original owner and I have the clear title in hand.
The shipping will take about 7 days and I will take care of all arrangements and costs. The car will be insured against damage or theft. All documents, including owner's manual, clear title and bill of sale will be provided with the car.
The price for the car is US $5,900 including all additional costs (shipping, insurance, handling).
If you're still interested in the car or you need further details please let me know. I would really appreciate a quick answer.
Thank you,
My brother found an add like this a few weeks ago, turned out that the car was heavily damaged on the other side that you cant see from the pics. Tried to remove a telegraph pole. $16800 sounds about right for a damaged R34.
It has to be a very bad smash to be only worth $16k, especially if it still has plates on it .
Its obviously a scam, you will probably have to send funds to some dodgy country and never hear of the seller again .
Well it doesn't look legit. Payment methods: "Money order/Bank cheque"....err thats a big money order/bank cheque!
Ebay has *some* forms of protection but at that price it looks very dodgy.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
