  • Replies 96
I'm always keen for a photoshoot! But will have to depend on time, date and place. Have a wife thats due in two weeks, so will need to see once you finalise the above. :O
Could you get her to delay a month or so...just joking :(
hope it all goes well for you both :P
At this stage, I'm wanting to do this, this coming saturday (16th of Sept). I would do it on the 23rd but unfortantly no can do as I'll be out at Jamboree as well as many others I'm sure.
Other choice is the wknd after Jamboree which will be the 30th of Sept.
So who would perfer which one?
16th or 30th of Sept?
I would be keen for this - just got some new coilovers put in, and have been waiting for something of this nature!!
has the place been specified?
Hinze dam has some nice backdrop potential!!
I have done a few photo shoots/cruises up there before with great results!!
just a thought...
Peter :3some:
We've seletced 1st of October night time to do the photo shoot based on the results from the voting.
We'll kick it off late in the arvo just as the sun is setting and then find another stop to do the night shots with a good back drop.
Any places of interest people can suggest? we have 2wks to now organise this properly!
Woody point
