  • Replies 96
I'm always keen for a photoshoot! But will have to depend on time, date and place. Have a wife thats due in two weeks, so will need to see once you finalise the above. :O
Could you get her to delay a month or so...just joking :(
hope it all goes well for you both :P
At this stage, I'm wanting to do this, this coming saturday (16th of Sept). I would do it on the 23rd but unfortantly no can do as I'll be out at Jamboree as well as many others I'm sure.
Other choice is the wknd after Jamboree which will be the 30th of Sept.
So who would perfer which one?
16th or 30th of Sept?
I would be keen for this - just got some new coilovers put in, and have been waiting for something of this nature!!
has the place been specified?
Hinze dam has some nice backdrop potential!!
I have done a few photo shoots/cruises up there before with great results!!
just a thought...
Peter :3some:
We've seletced 1st of October night time to do the photo shoot based on the results from the voting.
We'll kick it off late in the arvo just as the sun is setting and then find another stop to do the night shots with a good back drop.
Any places of interest people can suggest? we have 2wks to now organise this properly!
Woody point
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
