hi all
just wondering what is needed internally to build a rb20det to produce over 300rwkws?
are there any little tricks of the trade to building a solid rb?
what oil and water pump should i run?
what brand pistons,rods,bearings,bots are recommended?
whats the max lift cams i can run with the standard valve springs?
i have the turbo, injectors,exh mani, gate, pump and pump already.
cher cher
https://www.sau.com.au/forums/topic/133240-how-to-build-a-tuff-20/
Please read the Forced Induction Guide.
Is has a link to a thread about 260rwkw+ for the RB20.
Its over 6-7 pages in length so its possible some of the information is in that thread.
Personally, i think you are wasting your money :)
Personally, i think you are wasting your money :yes:
don't be so harsh on the RB20 Ash, you know it's got the minerals to keep other engines honest ;-)
You know the RB20/300rwkw is well above a 5000rpm adventure.
Probably...but if you have pistons, clean up the top end with some baby cams and some tweaking of inlet/outlet and chamber...nothing dramatic as ti not lose bottom end. The make sure you havbe oil pressure and temp well under control...then 1.5bar up a GT30R will net you close to 300rwkwsand still be pretty driveable
eh not quite man, i pulled 288rwkw on 17psi...and this was on a motor with poor compression.
its possible to do but there may be cheaper ways to go about this.
if you are interested in 'beasting' up the old rb20 take a look at my rebuild thread...ive done everything but rods in the motor.
A GT30 you'll be running ~25psi for 300rwkw
Thats a LOT of boost for not a large amount of power and even running a ball bearing its gonna be very harsh
Remember i ran 270 @ 17psi....
hey mate
if you wanna know how to build a tough rb20 pm dan ( 3lit3_32 )
his rb20 was good for almost 270rwkw (if not more) with a stock head.
he has almost finished mine which is almost identical to his but with head work done.
he would be more than happy to point you in the right direction
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
