Hello everyone out ther is SKyline land.
I have an idea about an event to be held. I know that you guys have had it in the past, but perhaps it's time to have another one.
DYno day. I've been to a few with my friends car club and perhaps it might be good to start to get a regular one going.
Would be great opportunity to, get members signed up, have a BBQ and generally just get to meet everyone and have a nice relaxing day, seeing how many ponies our cars put out.
Just an idea for people to chew the fat over.
https://www.sau.com.au/forums/topic/13331-idea-dyno-day-perhaps/
Does anyone know of any good Dyno places that may be a bit friendly towards a big group of us.
I'm from the Central Coast so the facilities are pretty limited, and I think that everyone would prefer a closer venue.
Good idea !! I just got my car back from Hill after new Fuel Reg, New Pump and new ECU map - Wanna compare to last time :D
I'm in - Unigroup are good !! BBQ is good - all proceeds go to B-Man's Electronic Boost controller fund !! Or maybe we can convince the SAU board to make it an official SAU day ??
Cheers,
God I hate dyno days at Unigroup.
Biggest waste of time EVER... They don't seem to understand the idea of a dyno day... It literally takes them about 30 mins to do each car, which means you stand around for AGES all day just waiting to see a few cars run...
A dyno day isn't meant to be a full discussion on what mods you've done, and how your car could be improved, and what mods they would suggest, and basically a general chit-chat for 30 mins... YOU GET THE CAR ON, YOU RUN IT 2 or 3 TIMES, THEN YOU TAKE YOUR CAR OFF... NEXT!
10 mins maximum. Can I suggest CRD or C&V for dyno days? They seem to run them much more efficiently.
edit: plus both CRD and C&V have 4WD dynos to cater for our GTR owners
Yep cool! I'm up for a dyno day.
I've only got a stock auto, but hey, what the hell... :Paranoid:
And as Endorean said, It'll be a good chance to meet some more of you guys and hopefully (finally) become a member of SAU! :headbang:
I'm up for that too - Jim as CAS tuned my Suzuki Gti about 10 years ago when they first started out - I wonder if he remembers me ?? He he
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
