Ok, looks like we're almost done. I will be posting up pics this weekend. Using the string + glue + metal wire really turns it from being just a seat cover into a retrim.
Jeez, my gf's parents must either love me or hate me by now, i've lived there for 3 weeks now.
  • Replies 129
Posted Images
I dunno about everyone else, but I can't make heads or tails of all the posts and different ways people have put their seats on.
JetDat is there any chance of getting some set of instructions or similar from UAT?
Cheers.
Im not sure if its me but the seat not look like they are flat..
what about the curves from the seat???
i guess seat covers are different from an actual interior shop...
but let me know if im wrong.. cause by looking at the Pics the curves are gone...
also just want to know when you sit into the seat does the actual material sink in? cause it dosent look like it stuck the the seat aswell..
Ozan and I put in an effort yesterday arvo and now the passenger seat is in my car - it looks unreal. Shouldn't take more than about 20 minutes per seat for my drivers & both his fronts.
Plan what you're doing, use the strings - crochet hooks are your friend.
Will post pics when done, probably next weekend.
there is a possibility i mite organise another group buy as i have friends who want some at the group buy prices...
but its a bit of work and i dont have the time lately...but i will see what i can do...
ok i just got a quote from a trimmer to rip out the cloth interior, add a bit more padding on the seats and install the covers + door trim + fix the centre console cover for $400.
car is r34 gtt and will be doing it on the 2nd week of october.
will post pix on how it will go.
Nice jonjon, I've found the seats are quite comfy and padded enough, but each to their own! Ozan & I will probably get a professional trimmer to do the door inners and parcel shelf.
Does anyone know of decent car upholsterers etc in Brisbane?
A couple of more pics
Hey Eddie, nice seats.
What colour is your car? Is it the stock silver?
I was trying to figure out what colour would be good for a silver car.
You wouldn't have a faraway pic of your car that shows the seats, do you?
After a mammoth effort, Ozan and my seats are done (pending a few little cleanup steps & replacing back seats).
They look the goods, I will upload some pics of work in progress & the completed product.
Depending how much I'm feeling like a perfectionist, I think I may redo the rear seat-back (the far driver's side strings) as they could line up a little nicer, but in general very happy with how it all went.
My niggle is that the embossing on the rear driver's side is imperfect, probably an inch or so offset so looks askew.
Final stage will involve the door trimmings and parcel shelf, and whatever else I think of if sufficient scrap material remains.
Cheers to Jetdat for organising the buy and Ozan for providing the workshop & extra set of hands where required.
I just want to say thanks to Arman (jetdat) for the awsome group buy.
I had a little trouble with one of my covers and he sorted it all out for me and its getting sent over now!
Tops to you Arman!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
