Why not the SSV? Tell your boss your not accepting that piece of shit :laugh:
Could have got it but then I would have to fork out the extra $$ for fuel coz it was just over the limit of my allowance with insurance etc.
I upgraded everything much as possible to same as the ss-v interior for cheaper.
Dezz
I test drove alot of new cars and the VE SS was one of the best for its price.
2nd on the list was the new wrx club spec 9. Exterior looked awesome but the interior was identical to the base model impreza.
Someone photochop my car......
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
