hi people
my r32 Gtr is almost and my mechanic said a twin plate was the go but not any more
and does not like triple plate and is now going for a quad plate now so has anyone got a quad plate, any comments
cheers
brendon
https://www.sau.com.au/forums/topic/133473-new-os-giken-quad-plate-clutch/
the number of plates has only a small bearing on the drivability of the clutch. the most infulencing factors are: clamp load of pressure plate, whether the plates are sprung centre or not, what design the plates are (puck type, full face type etc), and finally what type of friction material is used.
thank you
is it jerky and hard to drive on street
cheers
it will do that only if you want it to :down:
pedal pressure is slightly higher than stock but not unbearable like most single, it slips and is very driveable almost like a stock. the quad plate should last you a very long time too
no offence to the guys that posted above but saying stuff like "a quad plate is really easy to drive... etc etc" is like saying ice cream tastes good. vanilla ice cream tastes good, but scrotum flavoured ice cream may not taste so good. but they are both still ice cream. like I said above the number of plates has only a small bearing on how driveable/undriveable the clutch is.
this is what I posted before and it is still true.
I still don’t understand why you would want to go with a quad plate when a single plate will more than do the job, and be more driveable at that. Plus you could buy 3-4 new singles for the price of the quad
thank you people for commenting
the reason for quad is its a bit more drivably on the street (i was told)
you are not quite getting it yet. saying a quad is more driveable than say a tripple is not helpfull at all.
let's say on the one hand I have a tripple plate, spung centre, full face plates, organic friction material, 900kg pressure plate. on the other hand I have a quad plate, solid centre, puck style plates, high metal content friction material, 1500kg pressure plate. saying the quad would be more driveable because it's a quad plate would be completely wrong. it would be fare less user friendly than the tripple plate (in this case). i'll will say it once more. get over rating clutches in usuability based on the number of plates. it's a very small part of the equation.
and lol and 2rismo. you knob gobbler, i knew the scrotum ice cream reference would bring you back to the thread.
hi
beer baron im only going what my mechanic said im not sure what pressure plate he uses i only know its a os giken quad plate clutch
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
