0-100 km/h in 3 seconds? ive seen an R34 GTR with Rb26DETT do 3.4 sec too a 100... surely thats saving shitloads of money.
lol! dude this thing is doing it on 12psi, and its a v12 and Im sure it has a million other reasons why its worth it.
Clearly money isnt an issue with whoever built it.
https://www.sau.com.au/forums/topic/133618-v12-gtr-o/#findComment-2477991
I'm not interested to build a car with intake restrictors, limited aerodynamics and tons of weight ballast so the car will not enter any official competition. It will be used for exhibitions only.
Gaaaaay! I wanna see it go round a track or down the street :)
https://www.sau.com.au/forums/topic/133618-v12-gtr-o/#findComment-2478010
surely you wouldnt be able to drive that down the street...........i cant imagine how someone would be able to keep that at 60 kays!!! Probably be in 1st gear most of the time lol
But it would be awesome on the track!
https://www.sau.com.au/forums/topic/133618-v12-gtr-o/#findComment-2478057
