Hi guys,
im pretty new to the forum and to the twinn turbos setup. I have picked up a Nissan 260rs with an rb 26 engine in it.
I need the rich expertise from the forum people in regards of the estimates projected power output for the Rb26 engine. I have read alot and trying to find the estimated projection for the power output.
PART1
Now its a 98 Rb26 still stock std. I have installed a 3" front pipe onwards till cat back all the way with a high flow cat with SS core. Also i have installed a drop in replacement filter with K&N. Ive got the 2.5"dump Hks.
I also have aerospeed adjustable cams on the way as well. With this set up plus a Power FC and a Power Fc boost controller how much Hp will i get @wheels? STD AFMs are good up to 250hp @wheels or at crank? How different will a power FC boost controller compared the the HKS proV? Im thinking of using all the comps with PowerFC (Apexi)and the boost controller to matcj it cos the boost controller is able to feed the datas into the Power Fc.
PART2
Next stage of the upgrade is the turbos. I have made up my mind with the advice from my firends to run 2530 turbos. How much power @wheels will i get if the upgrades are added up together mentioned above? Do i need to upgrade the fuel systems such as the injectors, FRP and the fuel pump if i did only the part 1 and how aboout part 2 do i need to upgrade the fuel system?? If i do need to upgrade the fuel systems, im thinking of upgrading to 800c injectors, arising rate Frp id3.1bar@idle and a bosch 044 fuel pump. This was also recommended by my friend as well. The reason why i chose such a big fuel systems set up is in future if i decides to go for more Hp i can without wasting money again upgrading the fuel system. With this do i need to change any of the internals?
Im actually after between 250-300kw@wheels. Will a HD singplate clutch with increased clampng load be enough for this set up? Clutch im thinking of getting it from Jim Berry.
Any comments or sugesstions will be appreciated. Thank you very much guys
Edited by stasis
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/
if your power aim is about 300kw, you can run 800cc injectors the bosch 044 pump, and a rising rate fuel regulator would come in handy. the PFC is a good choice as many tuners know how to work the unit. but id suggest with running the 2530 turbs is getting some extensive headwork done with tomai poncams for your aplication id go with 254 deg IN and 254 deg EX at 9.15 lift with some porting and polishing, get some tubular manifolds with twin external gate ( I think HKS has them) and make the dumps from the turbos 2.5 inch and put in a nice 3.5 inch exhaust. on the twin setup i support the best flowing exhausts because the less restriction the better. the 2530's are resposive given a good tune. and a good high clamp force single plate will do the job just fine (dont know jim berry but i do know of the exedy hyperplate) but keep in mind that pusing your car at 300 kw that something is bound to break which would lead to a bottom end rebuild. and for the bottom end id go wiseco 87mm pistons, pauter rods, and if your cranck is still fine id have to be prepped and reinstalled, and while your at it put in a HKS harmonic damper ( make the car rev nicely:D:D:D
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2477418
u dont "need" cams for that power? external gates on 2530s, why? hks dampener is pretty over the top unless u are going over 9000rpm.
so with that out the way id go...
2530s
power fc
044 pump in the tank
700-800cc injectors
hks dumps r good
3.5' exhuast minimum
jim berry clutches ive been told are the best value
z32 afm's
nismo regulator
twin feed on your stock fuel rail
i'd personally upgrade the sump to bigger capacity (9L or so and baffles)
oil cooler is a good option
u can get some poncams as mentioned but they are not "needed to make the power"
like faid said 300awkw is gonna eventually need a rebuild and add some forged rods and pistons, n1 oil pump, oil restrictor in the head, acl bearings, a good head gasket and your pretty much set for good reliability.
i cant see why 450rwhp isnt possible with those mods if the tuner knows what hes doing. the rebuild wont add power but it will help it last a long time with that power level.
thats my 2c worth
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2477838
Lot of very bad information here
1) You dont need external gates
2) You dont need a rising rate fuel reg
3) You dont need 2530's for 300rwkw
4) You dont need extensive headwork
5) You dont need afermarket manifolds at all
6) 800cc injectors are far bigger than needed for 300rwkw
300rwkw on a stock RB26 is quite safe and fine.
What you want is the following:
GT-SS/R34 N1's.
550cc (or there abouts) injectors.
PowerFC
Adjustable Cam gears
You already have the dumps/exhaust so your fine there. There isnt much to getting 300rwkw from an RB26, and it can certainly be done a lot cheaper than you think as you dont "need" all the add-ons that really dont give you any gain
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2477931
GT-SS/R34 N1's.
PowerFC
Yep;what he said...
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2477970
2530s
power fc
700-800cc injectors
hks dumps r good
z32 afm's
nismo regulator
thats my 2c worth
Hi Brad,
wats a twin feed line?
How much will it cost me for " a rebuild and add some forged rods and pistons, n1 oil pump, oil restrictor in the head, acl bearings, a good head gasket and your pretty much set for good reliability." all up? I didnt take into account these and how much will they cost me for a rebuild and the parts for it? So if i change the cams i would be able to rev up to 9krpms? :sick: . And how much did you get your N1 oil pump for if you dont mind.
Part 2 upgrades are now getting longer in the list.
1.fuel systems which includes : 800cc injectors, FRP and 044s
2. Engine rebuild have to find out about the costs to this.
3. turbos 2530s
Brad what do i need to do for a higher rev since if part im rebuilding the engine. Must well if i only need the parts.. Thanks buddy
Im picturing tha faces of the FPVs and HSVs drivers when i smoked them using a wagon or a car like you sruise probably they will mistaken the car for a "DAMN VOLVO" :):P:sick: . :sick:
THanks buddy
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2477985
GT-SS/R34 N1's.
PowerFC
ok with only power fc with boost controller, cam gears will i be able to achieve 250kw@wheels?
The reason i went with 800cc injectors and the rising rate FRP is to make way for future upgades for the turbos if i want to.
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2478003
So do you want 300rwkw or not?
You wont make 300 on the stock turbos, so you have to change them, you have to decide then, do you want 300rwkw with lightning response, or 350rwkw with lesser response
For a street car the 300rwkw/response is what id be heading towards, and thats GT-SS/R34N1's turbos department
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2478052
YOU DO NOT NEED A RISING RATE FUEL REGULATOR. A 'rising rate' fuel pressure regulator increases fuel pressure at a ratio of greater than 1:1. What you want is an adjustable fuel pressure regulator that is 1:1 (boost vs fuel pressure increase). I am so tired of people reccomending rising rate fuel pressure regulators without any idea what they are. They have no place ever on a turbo EFI car that I can think of.
first think I would do is stop listening to your mate, and some of the people on the forum too. Go in to a competent mechanic, and ask them their advice. Also look at the RB26 turbo upgrade thread. That will be a good start.
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2478062
yes i do want 300kw@wheels.
Heres the thing im thinking of doing the upgrades in 2 stages.
First stage is the 3" full exhaust. i still got the HKS 2.5" dump pipe. with some cam gears and PowerFC w/bosst controller trying to achieve 250kw@wheels. With this set up using the std turbos do i need to upgrade the fuel system or not?
Second stage
Definetly the fuel systems have to be upgraded cos im changing my stock std turbos int othe 2530s. When changin the turbos i will then install the dump pipse altogether. With this set up i suppose i need to strengthened the internals? The reason why i chose the 2530s turbos is they dont cost much more than the N1s turbos. So what the heck must well get a bigger one.
Beer baron, i know what you mean. Im actually having my car to be tuned either at Racpace or Hypertech in Melbourne. Ben from Racpace has told me that with cam gears, drop in ai filter and power FCs w/ boost controller i will be able to attain +-250kw@wheels. Im just double checking cos i dint think the engine is able to attain that kind of power without changing other parts. As you know parts are very expensive!!! you have to shop around. The main reason why iasked in the forum is i want to make sure what people is saying is true and to let people see potential problems as well. So.. thats just me. Sirry if i have asked the wrong questions and i better keep my mouth shut then.
I will try reading other thread but is still not goign to be in my case will try my best to follow and check
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2478169
Im actually having my car to be tuned either at Racpace . Ben from Racpace has told me that with cam gears, drop in ai filter and power FCs w/ boost controller i will be able to attain +-250kw@wheels.
Your in good hands at least, dont listen to your mate. Ben knows whats going on and any advice he gives, is spot on the money.
And further to that, he wont make you spend money where it isnt needed
I've learnt lots from him, very wise he is
https://www.sau.com.au/forums/topic/133631-rb-26-set-up/#findComment-2478697
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
