Check attached pic. what concerns me is the engine is shown as a rb20dt, but i know for a fact its running efi. i can hear the injectors running and the mechanic who did my 100K service cleaned them...is this possible to have a turboed engine without efi?
also for people are after a nissan color code table i found this:
http://www.ttzd.com/tech/colorstech.html
seems like mine is still the original paint color, and its in pretty good nick for a 1989 car!
edit: just noticed that in the codes window it shows the 2nd digit, R, as being either a rb20dt or rb20det...
Sorry flagger, can't answer your question, but do have one of my own that I'm going to use your screen dump for.
Do we know what all the fields are and their possible values?
The top row is easy (vin,model)
the second row is also stragiht foward (series, production,ext color, int color) - though we should start compiling a big list of color codes startung with the link in the post above!
The third line has 4 fields
3.1) is the body type. 2K = 2 door coupe, W = wagon, 4S = 4 door sedan
3.2) Engine type ie rb25det
3.3) Drive system? ie 4wd, HI.2WD (does that mean hicas and 2wd? if not, what?)
3.4) model varient? ie Type-M or 25RSF (thats a stagea)
Line 4 also has 4 fields
4.1) Geabox type - AT, MT, ?
4.2, 4.3, 4.4 - not used.
Instead of entering the VIN number, just type the series in the 'Model Series' field (eg R33). That will allow you see all the available model variations in the drop down fields.
Anybody got anything else to add??
I'll keep on editing this with more information as people post it!
3.1) ??
Does anybody have more info than that, or know what 3.1 has? It seems to have things like '2k', or 'W'
3.1 is the body type. 2K = 2 door coupe, W = wagon, 4S = 4 door sedan
Hey,
Just wondering if someone could check this VIN:
6U9000ECR33111553.
Thanks heaps--also got the 56k modem problem :thumbsup:
-oz
Hi Team,
Is there a chance somebody could check the following VIN please - 6UN00WGNC34134121.
Any assistance would be greatly appreciated.
Regards,
Marc2
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
