Thanks Fonkeymonkey for confirming the 4/95 build date.
I purchased my baby from Unique Auto Sports as a 1995 V Spec. It has the V Spec badge on the bootlit and the usual V Spec components like the the fins on the rear diff housing.
What is the difference between a V Spec and a V Spec N1?
Thanks
  • 1 month later...
Can you please check this one for me:
ECR33-106340
The model code is GGKBRTFR33VZAAALCA
I do not know what the last letters stand for AALCA - can anyone shed some light on this?
Edited by Victory
  • 4 weeks later...
FB13-577940
hb14001299
Neither of these VIN's are recognised by my version of FAST, but if you type in 'B13' or 'B14' into the 'Model Series' area (and hit return), you'll see various drop down menu's appear from which you can select engine type, body type and a number of other options. That might narrow it down for you to something close to the cars in question.
It seems that cars manufactured outside of Japan are not covered by some versions of FAST. Mine does not cover Nissan models built in Australia, for example. If yours were built locally or outside of Japan that probably explains what's happening.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
