Its a Vspec or Vspec ii KBNR32RXFS7AA conforms that. its 02/94 model and sould be 326 in colour.
Lucky i did a bit more research on this ! the actual model number is not for a Vpsec at all!!! AA just means its a GTR model normal or Vpec .....what the actual model number reads as >
KBNR32 R X F S 7 AA
K: Coupe Not Present: Sedan
B: 2.6L (GTR)
N:Super Hicas + Attessa
R: 2 Doors
X: GTR (16 Inch Wheels)
F: 5 Speed Manual
S:S: Intercooler + Turbo + EGI
7: GTR
AA: GTR & V-Spec I &II (Non N1)
Always check this LINK >SKYLINE MODEL ID CHECkER
So Close to being ripped !
Edited by ish
Have a friend looking to buy a claimed R32 GT-R V-spec....can someone pls verify....
BNR32 302666
KBNR32RBFS MA
Thanks!
its has Vpec numbers Ie the B in the number states Vspec 17 inch rims ... the M in the model number is not what i am sure of
Edited by ish
KBNR32 R X F S 7 AA
B: 2.6L (GTR)
R: 2 Doors
F: 5 Speed Manual
7: GTR
How can, you say that you were close to being ripped off, all the numbers say is it may be a vspec nothing there to say it isnt a vspec.
the model number claim it to be a normal gtr hence the X: GTR (16 Inch Wheels) and the 7: GTR in the model number... the AA can be either.
i nearly took off to buy this thing thinking it was authentic...
Edited by ish
