HCR32-009253 - May 1989
HNR32-001731 - August 1989
HCR32-027344 - May 1989
HNR32-005374 - August 1989
Not to be rude, but are you 100% on those dates? Based on the chart here: http://www.gtrusablog.com/2013/03/nissan-skyline-r32-serial-or-chassis.html HNR32-005374 should have been manufactured in 1990s. Any second opinions?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
