Are you guys able to search for non skylines?
I have a '03 Gloria that I would be interested in seeing the details of:
HY34-709054
Cheers in advance!
Spec Codes:
RADGA = Gloria Spec Revision 2003, 04.
STTMJ = Leather Seats
TELV3 = TV + Navigation
  • 1 month later...
Would that have told me clearly if the Gtr was a v spec?
Yeah, it would have listed 17" wheels as well.
Not all 94 models are V-Spec II's.
Hey mate, what version of Fast are you using?
I use a Japanese Car Catalog, which has the data base of listings of the VINS.
  • 2 months later...
  • 1 month later...
Thanks for that, hmm its supposedly a vspec... but this clearly states it isn't. So many of the earlier models running around with vspec gear but not matching. Lots of dodgy stuff haha
Does you tachometre have an "A-LSD" light?
That will help signify a V-Spec...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
