Drive was nice out to hanging rock, everyone was spread out a bit more.
Pity there was very little there and a $8 charge to get out of the picnic area once your in.
Anyways good to see a legend remembered with a big turn out.
  • Replies 91
Hey ppls.
Yeah, I had a good cruise up until people DISREPECTED Peter Brock by ripping skids on a public road right neat the heart of Holden, the Engine Plant.
Peter Brock was passionate about road safety and I was dissappointed to see that even 30 minutes into the cruise people were acting like d1ckheads. It only takes the BIG moment that people had on the Westgate bridge to realise that doing the sort of crap you were doing on public roads is plain stupid.
I was hoping that in respect of Peter Brock that this wouldn't happen but I was sadly mistaken.
I know it was any import drivers, and I'm not going to name name about who it was, but it did make me sad and angry on the day.
Anyway well done to those who kept their sh1t together and acted properly on public roads.
BASS OUT (So much sausage I can never look at a BBQ the same way again)
Get a life dickhead.
I love flutter, I was fluttering every import and VL I could get next to during the majority of that cruise.
IF YOU GOT IT FLAUNT IT
Need I say anymore? :)
thank
you
Same goes for you rim. :P
Anyone spot the cop in the blue ford parked sideways near the normanby rd intersect on leaving?
Too bad the hot Porsche owner didnt as he gunned it pass all the imports/VLs.
Last seen the cop was hot on his heels :P
We saw the cop still parked there when us SAU guys left...thought he was just there to make sure no one was being a tard when leaving (which is fair enough) but he actually had the speed gun out on us....
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
