yeah ive buggerd my rails too using a trolley jack and theres no way of gettin it back to orignial for too...sigh. i was thinkin of making an insert on a lathe to sit in the trolley jack to make it fit like a normal jack.
as for jackin points....the manual says diff and crossmember.
  • Replies 75
Posted Images
supra,
My rails certainly aren't stuffed and I refuse to stuff them myself.
I refer to my earlier post if you are doing an oil change, by running up on one car ramp sideways !?
If I had to jack it, it would be by the crossmember /diff as mentioned by others.
El Bee
This is another manifestation of analness and stupid arguments with no evidence to back it up.
Those of you who say you are wrekcing the structural integrity of the car - do you actually know what the sills do? the little thin metal flap will just get flattened onto the sill. The sill itself does not actually get damaged, just the little metal flap gets bent. Have you actually felt it? it is so thing and weak and it does almost nothing.
I'm not saying jack up by the chassis rail, because that does get bent, and that is important. If the fatory jacking point it the sill, then it can take it. Does the standard jack bend the sill? NO! therefore by jacking it by the sill, the only thing you bend is that stupid flap that does nothing.
Besides, like i said, a lot of car garages hoist the car by the sill, and that flap does get flattened. Skylines are not special in this sense. All cars have that little metal flap and it gets bent. If you went up to your parents and told them about that on their car would they care? NO
:werd: I think you'll find *any* shop with a hoist lifts your cars by the sills. Some places put rubber pads where they lift but thats just how hoists work.
Floor jacks on the other hand should use the diff, gearbox or engine crossmember or a suspensions mounting point
Scary Story!
I have got a 1350kg trolley jack which the handle was so short that I can't even pump it outside the car. (as in the handle's length is still can't be seen if you look from the top of car down). I've got it in the air how ever, it's extremely hard to lift it very high. I used normal jack to jack up more, then trolley up again, then jack up again then trolley until the stands fit under the sills.
At this point, I placed the stands underneath each side's sill. and let go of the trolley jack, but oops, did it too fast with the release hydrulics... the car thumped down on to the stands! made a loud noise!!!!!! i was so freaked out!
i thought it stabbed right through the cabin or something!
But it didn't, I was pretty sure the gap b/w the stands and the sills weren't more than 2cm! I had real trouble getting the stands underneath the sills in the first place. When I did, there was hardly enough space for me to place a piece of wood in.
I realised the noise came from the metals hitting each other, as in the sills and the stand, there was no visual damage!
Can you guys tell me if there will be structual damage?
The reason i am jacking the car up is for service, change oil etc.
after this incident, I dropped the car back on ground! scared it would have done more damage! I found that I don't need to jack the car up for me to get to the sump plug, how stupid me!
=( Still shaking from that noise, it's like, ****, there goes my car!
Amazingly no damage noticed!
and yes I did use the trolley to jack at the front cross memeber! with a block of wood, hardly any noticeable change after it's down.
But take my advice, do not purchase the 1350kg jack from super cheap auto! the handle is too short, go for the heavy duty ones... like the next grade up! i fink this trolley jack is for little starlets! not skylines!
any one can suggest a good trolley jack with a longer arm?
sounds like you weren't careful enough with the release screw :) do have to be careful other you are right.
you generally always have problems with the big chunky one on lowered cars, even worse with a bodykit. I have great trouble even getting it under my sideskirts. And front similar story of getting to gearbox cross member due to 400R bar.
You can get a special "slim-line jack" which is better suited to our sorts of cars, but can cost a fair amount. I guess you only have to buy one once though and you will always have it.
yes it should be fine.. remember the actual jack load will be less than 1350kg as you are only jacking one, or at most two wheels. The rest of the weight will be distributed to those other points as the car is jacked.
You just have to make sure that screw is tight as buggery when you go to jack it up.
I also use a supercheap auto jack :Oops:
fatz also had one of those super cheap jacks, we had my GTR up on it and the jack twisted, bent and dropped the car.
Also inconvenient coz we didn't have another jack to rescue the bent jack from under the car. Not happy.
As for 1350kg, that should be heaps....how many wheels lift off the ground when you jack a car. The jack's only holding all the wieght if all4 wheels are off the ground :)
I'm currently getting one of these, $315 delivered.
dont buy that $ 30 rubish they are dangerous !! i've seen them twist and the car just drops .
spend like 150-200 and get a proper one ( still a cheapie ) i use proper commercial jacks that i've had for 20 years and still going strong ( i've changed the seals though )
supra dont put the stands under the sill put them under the rail you wont bend that .
the jack that comes with the car you put under the sill cause its made for it . and its only meant to be used to change a flat tyre thats it .
you say you can get under the car to undo the sump plug , sure you can but what about checking things like gear oil , cv boots , uni joints , oil leaks and what ever you got to jack the car up to do a proper service its much easier and you dont want to use el cheapo stands either ( made out of 1.6 mm steel ) they are to flimsey .
wrxhoon, yes, i take your word for it mate! it didn't sound right as soon as 2 wheels are off the ground, the spring was like , grung grung grung, gurnk ... and i can not lift it any more!
it was so hard to pump it cause the stupid handle wasn't long enough! god damn! I just hope there wasn't any structual damage to what I did today! =(
any industry trolley jack thats worth about 200 or so will do the job. compare that to 25bucks from someplace like supercheap and it pretty much answers all questions:D
yeah i agree that bending those flaps will do shiit all to the integrity of the car but boy do they look terrible when u do bend em.
and yes u dont need to jack the car up to change the oil:D:D
More Info?? what does it weigh, low hgt, raised hgt, what brand name??
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
