  • Replies 151
Looks very nice..
From a flow perspective; would it be better to place the location of the join on the inside of the bend instead of the outside?
Or if possible on a straight section.
I am visualising the air flowing through the pipe and as it follows the bend it tries to push up hard against the outer edge of the bend, it then approaches the join as the air is pressed up against the outer edge of the bend and causes turbulence as it tries to flow in to it a touch. If that join were on the inside of the bend I would think there would be less turbulence as the air can follow the outer edge of the pipe without interuption.
Is that the correct way to think about flow dynamics? I've done ZERO studies on flow dynamics so really have no idea; simply an attempt to visualise how the air flows through the pipe.
Reason I ask is I have seen many dump pipes done like this and always been curious.......
the other trouble is this is made out of a 3 inch mandrel bend and a 2 inch mandrel bend.
its a hell of a lot bigger then a normal low mount dump pipe.
so room becomes an issue.
the size of the pipes should more then compensate for the slight turbulance..
i hope
i hope
Don't get me wrong I wasn't trying to pick the design; in fact every other dump I've seen has the join on the outer edge. I'm hoping some one with a little flow dynamics knowledge will stuble upon my post shed some light as its always bugged me a little. :(
I have Never seen a dump designed the way I stated in my previous post.
But omg.. your dump pipe does look nice; the fit is very tight.
The .82 definitely looks smaller than the 1.06 iw i've seen.
it looks a lot worse then it actually is.
there is about 2 inches between the turbo and the guard and also about 2 inches surrounding the dump
pipe. once i cover it all in heat wrap and mount a stainless heat shield above and behind the dump it should'nt be an issue.
love reading about this sortof thing.
I was considering one of the turbo's when racespec announced them a while ago :sick:
Another question regarding your dump pipe, would the wastegate pipe cause any turbulance issues where it is plumbing back in? I'm just asking this because I was reading about BATMBL's pipes when they were first released and he tried to keep the wastegate pipe as long as possible to avoid turbulance.
keep up the great work!
At the moment I'm a little ignorant of the cartridge/s that this turbine housing is designed to mate with. Hence the question about the CHRA - I want to see what impellers this particular baby has...
Good work on getting the turbocharger part numbers. Pleasing to see that Garrett have brought out two A/R sizes; more options. Notice that the pics look remarkably similar to a HKS design with the divider cast between wastegate outlet and turbine discharge?
Was there any solid/reliable info from GCG as to what sort of power rating or service application (ie road, circuit, drag) these things should have with a Skyline?
the CHRA number would be the same for any cartridge with the same comp/turbine so its the complete assembly or unit number you want . Something worth noting is the part number stamped on the side of the exhaust housings mounting flange in the second shot . This would almost certainly be the turbine housings part number .
What I want to know is can these housings be grafted onto the GT37R cartridges because they have the potential to be better than the GT3540R cartridge for the larger/est RB - just need a suitable exhaust housing .
if it was me doin the pipework for that internal gate turbo i'd almost be tempted to run the wastegate pipe seperately.. i really like the internal gate exhaust housing design makes it easy for pipework i guess you could say.. on the design of your dump pipe.. if you can i'd be running the wastegate pipe a bit further down.. not a fan of running short wastegate pipes.. or plumbing them back in >_<
Dale as a generalization the GT3540R should make similar power to one with a free floating housing (meaning non gated) unless the gate cannot pass enough exhaust gas to properly regulate turbine/compressor speed and boost rise .
We now have all three AR sizes .63 .82 1.06 with IW so have some flexibility . The important thing to remember is that its not possible to run the smaller AR housings and expect the waste gate to make up the flow difference of a larger AR housing . Boost pressure is regulated by the waste gate actuator which uses a pressure signal from the compressor side not the turbine side . Exhaust manifold pressure/turbine inlet pressure/back pressure is dictated by firstly the turbine/housing and everything south of the turbine inlet . different sized exhaust housings are made to taylor turbine/compressor speed from the available exhaust gas velocity . It really is a juggle of turbine/housing size vs compressor size/capacity to pump air . If you use small AR exhaust housings on turbos with large high flowing compressors (GT3540R's one is capable of 70+ lbs airflow so 700+ Hp's worth of air) the higher exhaust gas velocity though the smaller volute passage brings the compressor up to positive air pressure type revs and if the engine is not running fast enough to swallow it you end up with either compressor surge or medocre low boost performance .
Its my opinion only but a .63 housing on this turbo is too small given its air pumping capacity , if the .82 is too laggy its trying to tell you its too much turbo - or compressor anyway . If smaller trim compressors were available in this turbo it may just work . Another maybe is to use port shrouded compressor covers to avoid the surge issue .
RB30DET's seem to handle the 1.06 ok and even the .82 for a roadie that does not use huge boost pressures . I hear people say that it works ok on RB26's as well though they are probably expected to lift their skirts at 4000+ rpm . I guess a serious track Rb25 with gearing etc to suit could use a .82 version . Gary and others have said that even GT3076R's can be a bit much on a daily driven RB25DET so the GT3540R being larger could be expected to have a higher boost threshold . This is normal when comparing a 500 to a 700Hp capable turbocharger . Power numbers are impossible to quote because the same turbo will give vastly different results on a real race engine compared to the production version it was based on . You can base turbo power potential off the maximum airflow it can efficiently pump (this is usually expressed as pounds per minute) though exhaust flow and turbine efficiency is just as important .
Out of here now , need some sleep (I know how Roy feels) .
Cheers A .
its all done..
i havent driven it yet, as i still have to put on all the heat wrap, and a heat shield.
but it all fits and sounds really smooth.
i will try and organise a tune for early next week.
Thanks Disco. All very accurate and correct observations/opinions. Definitely clears up some perceptions about the value (or otherwise) of various A/R combinations.
I had been considering whether this housing would at last allow a suitably flowing/efficient driving bolt-on 71/60mm cartridge out of the GT3071 family, and also for those wanting something around 5-600hp but still internally gated (82/68mm?).
It's almost like the different A/R is available so that we can use different cartridges according to the power:response balance being sought. Just a matter of determining the optimum compressor spec, then getting the turbine impeller + housing sized to suit (as per normal matching processes).
I'd just like to gauge what it has been designed to mate up with, and if the range of options available to us has been opened wide up. It is a really good development and hopefully will satisfy a demand that has existed for a while now.
Dangerman would you do us a favour and post up the CHRA number? Since you're one of the first (the first??) with this unit I'd just like to see what spec impellers it uses.
cheers
Dale
Edited by Dale FZ1
i didnt write them down before i put the turbo on but from what i can see its chra no. is
706451-5015
i dont know if thats of any help as i cant find much info on them as yet
706451-5015
CHRA No. 706451-5015 = 61.36mm, 56 trim compressor wheel and 62.32mm, 84 trim exhaust wheel.
Cheers.
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
