Guy who used to go by AJHudson on another board, used to drive or still does drive an R33, white and a GTS-T I think.
I am getting his old email address soon and will post that but does anyone recognise that nickname and can get him to contact me or give me an email address/mobile????
Email1: [email protected]
Email2: [email protected]
I can't get responses from either email, all of this info is from paypal but the transactions took place over the time they will investigate for.
Edited by Midol
https://www.sau.com.au/forums/topic/134056-guy-who-goes-by-ajhudson/
Guy who used to go by AJHudsen on another board, used to drive or still does drive an R33, white and a GTS-T I think.
Try doing a search, just type the user name in.
I tryed & there is nothing there, u might be spelling it wrong
DD Phil on car audio australia knows him to some extent he always seems to coment on what this aj dude is selling and has done some recones for his DD subs so if you get in contact with him and explain everything you might get somewhere?
fill us in on what happened? how did he screw you over?
I've got his mobile off a guy who bought an amp off him.
If we can't get anything happening over the phone then I shall get hold of Phil.
I bought a GT-28 off him, through paypal. After a month I decided it wasn't coming to find he had been banned from CAA and paypal wouldn't do anything.
well that sux, I farkin hate thieves and scammers.
Paypal should have more information than just his email address.
For him to receive the money from paypal he has to register and verify a bank account or credit card details.
That obviously means that there is a paper trail, leading to a bank account which he would have needed ID to open.
Don't let it go, it is only a small amount of money, but it is the principal that counts. If he gets away with this how many other people is he going to rip off before he gets caught.
The good thing is though if he gets caught and ends up in jail, you can rest satisfied that he will be in for some group lovin'
Good luck with finding the prick
Wasn't through ebay :S
I don't support buying Car Audio gear through ebay (Though through a forum is really no different than ebay.)
Was second hand gear from a forum, CAA. I just thought someone might know him on here since he has a skyline. The CAA admin have been helpful but same as me, all emails unanswered - that mobile is disconnected. Name brings up nothing.
New lead though, might take a while for it to come through.
  • 3 weeks later...
Just updating now.
He claims it is at a store getting fixed - for 4 months.
Hired a personal investigator now, when I find his phone number I am giving him a call and letting him know he has 3 weeks to refund me the $820 + PI fees or he'll be seeing me in court and if that happens I'll be claiming legal fees on top.
Have had a consult with a lawyer - he told me not to add the lawyer fees onto how much he owes me yet, only do that if he denies to repay the money.
tell paypal he scammed you, they'll refund you the money. i know this from experience
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
