hey i hav now sort of finished putting a 33 box in my 32 the only problem i have is with the speedo... i got the nissan navara one with the part number off these forums.. but the speedo is reading higher by about 20kms at 100kms. so when i am doing 100kms. the speedo is roughly saying 120kms.. am i suposed to pull the cog off the r33 speedo drive and put it on the navara one? i dont think its right as the r33 cog is a fair bit larger than the one on the navara.. and if i were to put this cog on it would read even higher... i may be wrong tho... any help would b good...
https://www.sau.com.au/forums/topic/134132-rb25-gearbox-into-r32/
  • Replies 188
Posted Images
Yeah dude, get photos hey. Someone had them before but I think with all the forum changes over the years they have vanished somewhere. Even if its just a pic of the two cogs together, then changed over.
the only problem is that i think i am going to have to superglue it on or something.. the r33 one has a c clip holding it on and the navara one is either glued or pressed.. i am about do do it now. i will take pics n get back 2 u's...
ok i still havnt changed them yet but i have a new problem... i cant get my reverse lights to work!!!! i have tried changing plugs, everything!!! they either stay on for every gear or are not on at all!!! can some1 please help? what are the 2 sensors that come out of the box for? 1 is obviously for reverse but whats the other??
Edited by lwboosted
Could be similar to mine was, so it's 'reverse' in every gear except reverse itself.. Was yours an auto to begin with by any chance? I had to rig up a negative trigger relay to get mine all working ok, so it reversed the signal.
Out of the box - one is neutral sensor, the other is the reverse.
nah it has always been manual.. just changing to aa 25 box, 1 way i hook it up the light is on in every gear including reverse, but not in neutral, the other way it does not come on at all.... why does it need a neutral switch???
I'm thinking your reverse light might be similar to my boot light. Bear with me here. :O
I wanted a second light in my boot so I slipped a wire onto the positive terminal and the second I just earthed. The light worked. What I didn't realise is that it didn't turn off when I shut the boot.
I don't know what the concept is called but it's something like 'negative switched'. Basically if you use a normal earth the circuit will be complete but the switch is on the negative side of the thing you are powering up rather than the positive which is what I was expecting.
So (here comes the relevance) if you are earthing your reverse switch the wrong way the lights will always be on and if you think the wires are just back to front they will always be off. You need to find the right earth for that switch.
Now I wouldn't have a clue about reverse switches but your story just rang bells for me and my dilemma with my boot light.
ok i will give that a go with the reverse light....
now i have just been spending the last couple of hours changing the cogs on the speedo drive.. and here is what i am up to...
this pick shows the two speedo drives together... the r33 and the nissan navara one.. as you can see the r33 cog is considerably larger than the one on the navara...
in this pick i have got both the cogs off, the r33 one comes off easilly as it is held on by a c clip, the navara one is very difficult, as you can tell and i just hacked the stupid thing off!! but as you can see it is pressed/moulded on, so u have to cut it off...
here you can see the two shafts together so u can see the difference.. you have to drill out the r33 cog a bit to get it to fit on.. i used a 9.5mm drill bit and it was a bit too small, and i cracked the cog!!!!, so i am now waiting for the superclue to dry and i will drill it out with a 10mm bit. hopefully it wont b too loose. but i will glue it on to be safe.. i will get back to yous when done...
the speedo was accurate when i finished and put it back in and everything.. but just then the speedo stopped working so i think the cog has fallen off in the gearbox... and i dont think i will be able to get it out without pulling it apart... so i was wondering if you guys would know if it is dangerous leaving it in there? will i do damage to the box? it is only plastic so would it just grind up? then i will change the oil in a month or so and it will come out when its a bit smaller?? lol wishful thinking...
mines done the same (crappy glue). last time i pulled it out it was still on the end...
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
