Anyone else using the Cooling Mist kit?
Who's using boost input, AFM input, combination of both or perhaps you've modified the software?
Either way, absolutely zero knock.
Uses very little water/methanol on a highway trip and no more flashing yellow light.
You could be tempted to add even more ign.
Fantastic.
https://www.sau.com.au/forums/topic/134151-cooling-mist/
i had a basic cool mist setup on my vlt ran 20- 28 psi on a na convert and made 253rwkw on 20 psi also ran 13.2 @124 mph with the thing at hethcote (28 psi) (couldnt get it off the line with out smashing the shit out of axels)
good value but i wouldnt rely on the system mine was there to prolong the abuse of the motor. it worked lol
i also ran 17 degrees base timing with the thing.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2490806
i am a big fan of water and water/meth injection, i used it on my own turbo saab back when i started out and it went VERY well.
ive actualy got a new aquamist 2d system here that once i get the car fully sorted will be going on, cant beat the cooling benifits it offers.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2491961
best place is as far away from the tb as possible and just past the intercooler outlet, spraying before the intercooler will result in puddles of water in your intake system.
placing the injection nozzle far away from the tb is good because it allows for maximum atomization and mixing with the charge which results in cooler,denser charge.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2493064
best place is between the TBand IC as long as its able to be atomised properly,
before the IC is not good as the water can condense in the cooler.
edit: what he said ^ I was typing mine when he replied :)
also Ive seen silicon piping joiners with a nozzle attached through them, good idea if you dont like welding
Edited by midnight
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2493065
one of my supra friends pieced together a kit using an RV pump as the pressure source, has an accumulator to keep pressure up...seems to work well.
the aquamist kit is a very nice kit, well made and robust...pump that comes with it is high pressure (100psi) and is purpose built.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2493846
The pumps are typical Sureflow etc 12V water pressure units, usually set at 60psi.
With anti syphon, non-return valves, filters and block nozzle detectors, there's a bit of gear to mount neatly.
From feed back I've received, it makes no difference where the nozzle is mounted as there's a LOT of air blasting past it at WOT.
I used the J-pipe as it's easy to drill and tap.
Have experienced no missing or hiccups as the mixture is injected. You wouldn't even know it was running except for the warning light.
Try the coolingmist website for more info.
I have R33 fit up photos for anyone interrested.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2494233
I like water injection myself,read a bit about it but never used it.
How would a mech and electric water inj kit work anyway? I've read if it was correct for the electric kits theres a sensor for the injector etc.
on Ausrotary RICE RACING makes his own.Good results.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2495855
have seen it setup on a 200sx
it used a hobbs pressure switch for manifold pressure
so i think it came on past 8psi
it was a car dr drift had done
it had a dash warning light for low water/meth
not sure where it injected it to, logical would say just before throttle body.
you shouldn't need to run this to take away knocking, unless you only have access to local penis fuel where you live (like the mafia). if you are getting yellow flashing engine light in normal conditions you need your tune fix, using meth/alky is only hiding the problem.
with this u can in theory dial in more ign timing and boost but once the water/meth is out or disabled you need to basically undo those temp changes otherwide it could detonate itself to death
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2495878
Unfortunately all our fuels are down on octane compared to the japanese cocktails available from their bowsers. We'll definatley be dialling in more timing - being careful and keeping an eye on things. It'll be interesting to see how it goes with 98 octane fuel + water meth.
Interestingly the knock levels come and go depending on the petrol station and I only use one brand of fuel. I guess it just depends on how long it's been sitting in the petrol station's tanks and what the owner wants to call it - I'm sure I've bought dodgy 98 octane fuel before.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2496366
Well a water injection kit of $850 once off and then its just the fluids costs which isnt much. As opposed to say buying 110 octane race fuel every race meet. Tell me which one would you buy and use and think is cheaper. I know one weekend of racing for us using 110 race fuel is not far off the price of the whole kit.
I honestly dont believe it is always totally masking the real problem, though im not saying it cant be used that way. Your car can be tuned to as good as it can get with your setup and anymore boost or ign advance would see too much knock and all conventional measures result is no reduction of it, then especially for a racing application its a relatively safe and cheap way of keeping knock down for safety or to allow for more power.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2496374
ive found that water injecton is good for keeping temps down as well as egts when doing long pulls or track time.
it cools down much more than just the charge, cools the plenum, head, and the valves.
not to mention a car that has had water injecton run on it looks 100X better when torn down than one without, valves are usualy spotless and the head clean enough to eat off of, so it really does 2 things at once; cools the charge and cleans the head.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2496389
Most members don’t realise how sophisticated the controllers are.
It’s not just an on/off boost controlled switch.
That’s why I asked what methods other users had tried.
The controller has pump duty cycle and inputs from boost or AFM.
Also via laptop you can tinker with the software to adjust ramp rates etc.
As for costs, $288 for 200L of Methanol isn’t too bad at all.
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2496434
I'm using our xede to drive a PWM output to an aquamist control solenoid. The xede will have one MAP Bank that will be used for a lean cruise function where it changes the volatges on both 02 sensors so it trims fuel around say 15.5:1. The PWM output will be mapped in 3d with one variable being RPM the other an EGT feedback. The other switched map will be for big boost where the water injection is just mapped with boost(or AFM) and rpm. I will aslo have TPS based and MAP based boost control on this MAP Bank.
Edited by rob82
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2496464
Definately.
Also you don't have to spend $850 if you look at some US sites. Mine cost less than $500 delivered from a company over there, although the price has come up a bit since.
http://www.rx7store.net/category_s/89.htm
Cheers
Edited by gtst25
https://www.sau.com.au/forums/topic/134151-cooling-mist/#findComment-2499669
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
