yep fred from pro trans did the box for me i think its gonna be a big difference especially with the trans brake neva used one .. has anyone here used a trans brake whats it like...
Edited by campbell
  • Replies 74
the hardest thing about using a transbrake is getting used to not hitting the brakes when you hold it flat but its easy
just get into stage hold the button until you hit the right boost or rpm
i leave the line at 5000rpm with 10 psi boost
any questions pm me
put a boost gauge and 5" rev tacho close to ur steering wheel so u can c it straght and clear. I have 3 speed in mine. 1st u switch your transbrake solenoid on, hold the button then rev it to 5,000 or something, boost will hit 15-18psi. leave the button then you'll get "quickest launch ever". dont hold that button for too long, 5-6 sec max, other way u will cook ur trans. get a big trans cooler !, and dont press it again when you launch, your trans will go back to reverse and brake ur auto internals. autos are jsut like a tune and engine, you need correct stall size to suit ur turbo, and cam and then retune it to match everything... very hard man. You bought the best auto for drags, good luck
Love the sound of the T51R, always have and probably always will :P
As for being the quickest, I'm not sure about times but there was an R33 running a factory-capacity RB25, making 795rwhp getting around Brisbane, was built by Hardcore before they ceased operations and had NIS33 on the plates. Also, 40RCD (now TRY09) might be worth checking too, I don't know if it still runs an RB25 bottom end but last time I saw it, it was running some very decent times. It was definitely 2.5 litre when it was running mid 10's, and I'm fairly sure it was still 2.5 when it broke into the 9's too, but I don't know about now :)
Best of luck ;)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
