  • Replies 40
i cant wait to see one of those maxda 3 turbo's worked too 250-300kw
FAAAAAAAAARRRK!
I wouldn't.
220kw is about the limit for a front wheel drive. Even prior to that you start to see hideous amounts of torque steer (plant your foot, go left!).
Its well known in the UK where they have many "hot" front wheel drives sold from manufacturers.
RWD and adjustable AWD for the win.
Haven't driven either of them, but independent testing shows the 3 MPS is in fact quicker...
At least in gear I reckon a 3 MPS would take off. The launch of the 6 MPS gives it the 1/4 time advantage. Roll on would be a different story.
Karen and I took an M3 (just for you Daveo :D ) MPS for a drive a week or two ago, and I have to admit I was more than a little impressed. I was a lot more impressed than I expected to be actually. That said, FWD dynamics don't really do it for me, and it apparently has a stability control thing in it, so I deliberately botched a corner entry to test it and it happily understeered towards the side of the road lol. In the rest of the corners it seemed to hang on quite well though, maybe they've tried to make the stability control not too intrusive? Powering out of a corner was frustrating but something I could live with given the rest of the package.
I thought the interior was fairly nice, the seats and pedal placement were good, the wheel is adjustable for reach and tilt and the dash is fairly easily readable. My only gripes were that some parts of the interior felt a bit cheap, and the clutch was really grabby, nearly as grabby as my old 5 puck brass button - it went from nothing to fully engaged in probably 10mm of pedal travel. This is fine if you're expecting to do a fair amount of track work or hard driving, but for a vehicle that I personally see as a quickish road car rather than something I'd be wanting to take to the track all the time, it's a bit annoying.
Gordo, peak power to weight doesn't tell the whole story, these things make stupid amounts of torque from 3k up until nearly the redline. In gear they are really quite impressive :(
but look at the 294nm of torque @ 4800rpm in R33 compared to 380nm @ 3000rpm in MPS...not that i would choose one over my R33 but its quite impressive
Which indicates the Mazda 3 has a higher average power over the rev range.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
