Hey people,
Got my motor rebuilt about 9months and the Piston that were meant to be put in were Arias Forged Pistons 20tho! I have had problems with compression ratio's so the head has been pulled off and on top of the pistons there is this information
RA9603X 0.50
RIB 0.10R1
Can anyone shed any light on these as to what specs these pistons are? As we are trying to work out the Current compression ratio of the motor!
Any help would be appreciated!
Cheers
Alan
https://www.sau.com.au/forums/topic/134445-forged-pistons/
Well they are 20 thou over....the 0.50 is the oversize measurement. Havent you got a spec sheet with the pistons when you bought them? Or cant you get them from the suppliers website? That will have all the info you need about the piston inorder to work out your CR, more importantly you need your head cc and headgasket thickness. Head cc should be about 64cc i think.
https://www.sau.com.au/forums/topic/134445-forged-pistons/#findComment-2498772
Hi al_r33
I have 3 sets of arias forged pistons on the desk with me they are rb20det 78.5 rb20det 79mm and a set of rb25det 87mm pistons,none of them have any information on the top's of them they are all marked with a job no on the bottom of the piston and thats it no other marking's .I had to go to the aria's web site to find out what they were just had to search the job no in, so I'd be a bit dubious they were aria's unless someone else has a bit more info than I do
Cheers Peter
https://www.sau.com.au/forums/topic/134445-forged-pistons/#findComment-2498879
Mine are 40 thou, but were never installed. . No actual spec sheet. This is the meaning of the markings, as explained on the box:
RA9603X = Part Number
0.50 = Oversize (0.5 mm / 20 thou)
RIB = measure bore clearance at RIB (= Bottom / skirt) of piston
0.10 = Piston to bore clearance (mm)
R1 (RI ?) = Batch number
Contact ACL, and ask them the cc of the dome for your C/R calculation.
https://www.sau.com.au/forums/topic/134445-forged-pistons/#findComment-2502242
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
