Hi guys, just a heads up we're trying to get a GB happening on metalcat hiflow catalytic converters on the AUS300zx forum. The thread is here
clicky for anyone who wants to check it out.
Basically we're looking at $560/pair delivered anywhere in AUS for the 200 cell, stainless, warrantied and street legal "metalcats" that have been advertised in Zoom etc lately. RRP is usually around the $350-$380 mark.
Please post in this thread (I'll check back regularly) or the one linked to above if interested.
Cheers
https://www.sau.com.au/forums/topic/134495-metalcat-hi-flow-cats-on-aus300zx/
  • Replies 92
Hi Rob260
I would also be interested, but as StageaGirl said, us ion the straight 6 land would only need 1 cat and it would need to be atleast 3" daimeter.
are you able to scorce these and if so for what proce?
THanks
Hi guys. can do 3" at the same price. Individual quanitites is fine so you're both covered. Can you email me some contact details? I'm still new to this forum so hopefully I've checked all the right boxes etc to get the emails...
CEF11E can do mate and yes 3.5" and 3" the same price. I'll check about the flanges and get back to you ASAP.
mrgilly, as far as the timeframe goes it's pretty flexible. I'll be taking a 50% deposit up front, then placing the order with PSI, then the remaining 50% will be due when they are at my place ready to post to you. Most of the orders are coming from AUS300 forum so it'll depend when they get deposits in etc but I'll keep you all updated. Should be OK for the supra, just let me know what size in/out
Edited by Rob260
Sounds good mate I will PM you when payment is required. It'll be 50% up front and 50% when they're ready to deliver. The delivery time will vary on supply, at the moment they have heaps in stock as just had a big shipment but could be up to 4 weeks if they have to get more in from the US. Just waiting on the AUS300 guys to get it all together at the moment it looks like the order will be going in on the 29th sept.
Anyways I will PM you with exact details when they are available.
Cheers
Rob- ill take 1 x 3 inch MetalCat @ $280
Thanks
Will do, you're on the list. At this stage I'll be asking for deposits next week and hopefully place the order on friday
Hi,
I would be interested in a 3" (in/out) with flanges for a R34 GT-t. Let me know when u want the deposit.
thanks.
Im also keen.
Need one for the GTR - they put a 2.5 inch one on in compliance - and its shit.
Ill see which I need (3" or 3.5") and get back to you.
Daniel
Hi mate, just confirming cost for 3" cat is $280 delivered. It can be supplied with flanges to suit skyline for an additional $65, or you can get it done at an exhaust shop. When I got mine done (300zx) I just had the exhaust guy weld up some flanges which is pretty standard. Hope I've answered your question!
i'd be interested in a 3" to fit my r32gtst
so whats the go there is it
280 with 3" flanges
or + 65 to have 3" flanges welded on??
too easy mate, check it out and let me know when you're ready
Im also keen.
Daniel
Good question, if I was you I would play it safe and get the exhaust shop to do it. Stagea's are still pretty uncommon here and even more so in the states (where the cats are manufactured). Cat will fit up no problems but if I was you i'd leave flanges to the exhaust shop
Anyone know if these flanges will fit the stagea?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
