  • Replies 92
Hi again,
Can i please order another one as well. 3" with no flanges.
So my order in total is:
1 x 3" with flanges for a R34 GT-t ($280 + $65 = $345)
1 x 3" with no flanges ($280)
so the total is $625. Let me know when u want the deposit.
Thanks.
Still aiming for an order on Sept 29th? I'm in, flatmate won't get one for his supra now as the head gasket blew...
Out of interest, will the 3" fit a MY04 WRX?
Ouch that doesn't sound good... Yeah should fit WRX just fine, but I will confirm with distributor
OK we're ready to go with the orders, and everyone who has so far expressed an interest has been sent a PM with further instructions.
I'd like to have the product ordered by this coming friday 29th so that's when the cutoff will be. Pls check your PM and follow instructions so as to keep this easy for me!
Cheers
Rob260 - I'm looking for a 3.5in with flanges for skyline - am i too late? PM me the bank details and i'll drop the $345 in tonight.
Rgs,
Kot
You can still make it mate, PM sent
Rgs,
Kot
A big thanks to everyone who's paid/been in contact so far, this is going soooooo much more smoothly than it could have!
The final numbers will be going to PSI tomorrow and when last I checked they had HEAPS of stock so with any sort of luck you'll all be seeing your cats inside of the next two weeks
Confirmed Buyers:
Can everyone pls check this list, pls note it is of confirmed buyers only ie have paid deposit. There's still time to pay but I just want to make sure my records are up to date so far
AnFz 1x3" and 1x2.5"
Stagea Girl 1x3"
Slippery 1x3"
Black Widow 34 1x3" and 1x3" flanged
CEF11E 1x3"
GT-T R24 1x3"
The PM hasnt arrived - system must be flaky. Can you email me at adam at jaftan.com.au instead? Or call me on 0414 864 732?
Cheers,
Kot (Adam)
Group Buy is closed with the following
Stagea Girl 1x3"
Slippery 1x3"
CEF11E 1x3"
GT-T R24 1x3"
Mr Kotter 1x3.5" flanged
Will PM as soon as stock is ready to send
Hi guys just a quick update, there was a bit of back and forth between myself and PSI during the week with some late orders etc. Anyways the order has been placed and all money sent to them (which I had to do over two days due to transfer limits etc) so it's now just a question of funds clearing and the stock being delivered.
The cats are all in te country so we're not waiting on a backorder or anything.
Sorry to bore you all with the details but I want everyone to feel 100% informed. At this stage I am hoping to take delivery by wednesday at the latest, and post to you guys as soon as I have the balance payments.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
